1982 CE cross fire no spark
Old Nov 21, 2021 | 11:29 PM
brad1955's Avatar
brad1955
Default 1982 CE cross fire no spark
Ok have a 82 CFI was running strong/ started running like crap
now will not run at all..... no spark.....12 volts @ distributor, new coil, new rotor,new ignition module,new rotor cap, pickup coil test within parameters..... fuel pump primes as it should .....any thoughts.....
Old Nov 22, 2021 | 04:59 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
My thoughts, one of those new parts is defective. I had a coil fail about 10 years ago. went into Eagle Auto in Brisbane and bought a new coil. Put it in. No spark!
I was certain it was the coil. spent hours checking everything. did an ohm test on the new coil. Junk!
Took it back, got another one. car still runs.
Old Nov 22, 2021 | 07:39 AM
Fast81's Avatar
Fast81
Had that happen on my 82, replaced all those same parts -- it was the HEI harness that links the Ign Module up to the Coil cap. IIRC ~$15 on Amazon.
Amazon -- GM part # 19207437
Old Nov 22, 2021 | 10:24 AM
Lakeside49's Avatar
Lakeside49
You might have forgotten to transfer the metal ground strap from your old distributor cap to your new cap. It is essential. Your new coil plugs into it.
Old Nov 22, 2021 | 01:23 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Do you have a GM service manual?
Old Nov 22, 2021 | 05:14 PM
brad1955's Avatar
brad1955
Manual is in the mail..
Old Nov 22, 2021 | 06:37 PM
Buccaneer's Avatar
Buccaneer
Old Nov 28, 2021 | 11:48 PM
brad1955's Avatar
brad1955
Update have spark have good fuel flow try’s to start will run for a few seconds right on the edge any ideas?
Old Nov 29, 2021 | 01:36 PM
Fly skids up!'s Avatar
Fly skids up!
Originally Posted by brad1955
have good fuel flow
What's "have good fuel flow"??? That means nothing. What's your fuel pressure?
Old Dec 1, 2021 | 12:41 AM
brad1955's Avatar
brad1955
New pump nice prime nice pulse
Old Dec 1, 2021 | 06:00 AM
Fly skids up!
I would still check the fuel pressure. I have a friend with a 86 tpi Corvette with a bad new pump. His car was very hard starting. So don't assume anything. Did you just put gas in the car right before it started running poorly? To rule out anything fuel related try running the car with a squirt bottle with fresh gas down the throttle bodies. Recheck the firing order too. Remember the 3 things a engine needs to run, fuel, spark, and compression. So if the first 2 are there check the compression. The timing chain might have gone bad.
Old Dec 1, 2021 | 03:20 PM
brad1955's Avatar
brad1955
This car was barely running when i got it started replacing sensors got to the point where it would start and run // but was running very rich
and would never settle into a nice smooth // idle no cel so no codes// checked bulbs seem to be ok// all of a sudden started running like crap then would not run at all. / all of a sudden no spark/fire.. added new coil /rotor/ cap/ ignition modulator finally the harness exiting the distributor was bad. I have spark/ i have fuel ( new fuel pump) car tries to start may run a second or two / seems to be right on the edge . if you pour extra gas no results//.Injectors prime like they should and pulse fuel when cranking // when the car would start it had a very nice even fuel umbrella type spray coming from the injector..... .. I have a chevy manual just trying to work my way through it....Thinking the ECM could be bad hence running rich no smooth idle..... could the ERG valve be causing any of this? How about torque converter solenoid? Just looking for input // one guy said check the ignition harness and apparently, he was right.. So I
have fire and fuel. engine seems to have good compression because it ran really well when it ran just not starting now this is my first computer controlled corvette //????
Old Dec 1, 2021 | 04:54 PM
Fly skids up!
Brad, timing chains can jump a tooth any time so rule that out with a compression check. One more thing comes to mind. Because the car was running rich you could have a block catalytic converter. Unscrew the O2 sensor and see if it starts. I don't think a ECM is your no start problem. Running rich, yes. But nothing would surprise me.
To 1982 CE cross fire no spark
