TI Dist. Readings
Old Dec 15, 2021 | 02:31 PM
joescvette's Avatar
joescvette
Default TI Dist. Readings
Hi, I have a 69 427/435, checking out the dist. before I install it. What are the normal readings on the pick up coil, I get .601 ohms on the two wires, out of car. The ohms move up and down slightly when I move the wires.
Old Dec 15, 2021 | 04:30 PM
fstntq's Avatar
fstntq
Sounds about right.
https://www.tispecialty.com/articles/article1.htm
Old Dec 15, 2021 | 11:36 PM
joescvette's Avatar
joescvette
Thanks for the response.. fstntg
Old Dec 17, 2021 | 06:41 AM
3X2's Avatar
3X2
I'd suggest using a mity-vac and cycle the vacuum advance a few times while reading the ohm meter to check for drop outs in the readings..
Old Dec 25, 2021 | 05:56 PM
joescvette's Avatar
joescvette
I used the mity-vac on the vacuum advance and the #'s stayed the same. Is that good? Thanks
To TI Dist. Readings
