Horn not working
Old Dec 23, 2021 | 05:38 PM
Marco Romero's Avatar
Marco Romero
Default Horn not working
Hi, I’m working on my ’81 and I can’t figure out why I’m not getting electricity to the where’s that are supposed to be at my horn. I’ve double checked the horn assembly and I’m pretty sure I have that built correct. If anyone could help I would gladly appreciate it
Old Dec 24, 2021 | 09:49 AM
Budryzer's Avatar
Budryzer
Just an FYI, My fuse is pulled for my horn to work because the clock is on the same circuit and was draining battery.
Old Dec 24, 2021 | 10:37 AM
Last Triumph's Avatar
Last Triumph
Have you tested the horn by adding 12V to the unit directly to rule that out first?
Old Dec 24, 2021 | 01:53 PM
Marco Romero
I have replaced the horns, I have a good relay, and I have electricity in my horn wires. But when I press on the horn I get no sound
Old Dec 24, 2021 | 02:06 PM
Last Triumph
I can only speak from experience - put 12V to the horn to make sure they sound before going further. I've just been down this very road.
Old Dec 24, 2021 | 02:11 PM
WC444's Avatar
WC444
Cruising
My horn wasn't working either. The Bubba who I bought it from mentioned that he had "worked" on the steering column. I took the horn button off and found that he had inserted the horn button's contact pin upside down.
Old Dec 24, 2021 | 03:36 PM
Marco Romero
Just finished working on it. And I made sure there was power going good like you had said and I got it fixed now. The owners before me had wires going everywhere from some cheap horns they bought and I had to order the whole button assembly. Thank you for helping out.
Marco Romero
I could use some help on figuring out the easiest way to install this new windshield washer reservoir that I bought, as once again. These past owners took this out as well. Lol
Old Dec 24, 2021 | 09:38 PM
jpatrick62's Avatar
jpatrick62
Troubleshoot horn electrical problems like any other electrical issue:divide and conquer. First disconnect the battery. Now, disconnect the black lead (on my 69 it is black iirc) at the horn relay and connect your ohm Meter to this wire. When you press the horn button, this should show ground. If this does not happen, the issue is from the horn button to the relay. If this works, hook up the black wire and connect the battery. Put your VOM to read volts and place the VOM lead on the green (on my 69) lead that goes from the horn relay to the horns. When you press the horn button, you should see 12 VDC here. If not, then the relay is defective.
To Horn not working
