I have a good condition 1982 c3 CFI with a high idle problem, and I want to diagnose the broad system that is causing it. Cold run notes are as follows:
Time 0m 0s (0:00) Starts immediately at 700 rpm, 40 psi oil, coolant cold
1:30 climbs to 1600rpm
3:30 drop to 800rpm
5:50 750rpm coolant ~120
7:00 800rpm coolant ~130
10:00 850rpm coolant ~130
12:00 900rpm coolant ~130
15:00 tach 900rpm coolant ~130
stabilizes at this level
Heres some stuff I've already done.
1) set timing back down to 6 degrees, was at 13 before
2) blocked off all headlight vacuum lines and the vac line going to the air throttle thing next to the air filter
3) I tried blocking the air passage to the IAC at 18:30, rpm drops to 850rpm but not more. Uncovered IAC and it goes back to 900
4) I've searched for vacuum leaks like hell. I can't seem to find anymore
Can someone tell me some diagnostic procedures to figure out what system is causing the problem?
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Originally Posted by nitan2k
I’m not sure. How do I check what tps is set to? I have the shop manual too but can’t find it
If you have the GM manual, it's in there for sure. Look on page 6E-60 under TPS Adjustment and it continues on the next page 6E-61 with pic.You need to set it to that value, .525v.
ok thank you. Can I ask what makes u think the tps could be the issue?
How are you checking the coolant temperature. 15 minutes later and the coolant temperature is still only 130? Like I said in the other post IAC position is based on coolant temperature.
sorry, should’ve said engine temp rather than coolant temp. That’s my mistake I had to write this quick. I checked it on the gauge. When I covered the iac ports after the rpm stabilized rpm drop was about 50. Also the times are timestamps
The engine temp is coolant temperature. Are you sure that your thermostat is good? A simple thing like a thermostat could be your whole problem. These cars don't throw a code for low coolant temperature like OBD 2 does.
Even 160 is way too low. The Crossfire system will never function properly if the car never comes up to temperature. You can check it a number of ways. Just put a new one in. They're cheap enough.
replaced board and thermostat. Did another idle test run. Engine temp Settles to about 180-195 and doesn’t go past 200. What else can I test? I didn’t drive the car, only idled it
Remove the ECM fuse (located in the battery box) and leave out for a few minutes, reinstalled the fuse and drive the car and get it up to at least 40 MPH for a few miles. This will reset the ECM. The ECM has to learn the idle.
Oil pressure light? Also, Im not really worried about it blowing up. The reason why I wanna fix high idle in the first place is bc when I shift into drive, the car jerks alot, which I think is causing damage to the transmission/flywheel, not to mention the mounts. Otherwise to be honest I wouldnt really care much. Thats the only major thing I have to fix before Im comfortable driving it regularly.
Understandable. Just try removing the fuse for now.
Also, do you think the engine temp not going past 200 at idle is still cause for concern?
No, that's great! There are people here that would give their left nut for that!
