1979 Build Sheet retrieval
I reached my hand up the forward driver side corner of my fuel tank and can touch the build sheet. Is there a way to lower "just a little" the one side of the tank to remove the sheet? Its folded into 4 I believe. I don't want to drop the tank. Can I just lower the spare, and is there a mount that I can loosen or disconnect to get me about 1 inch of clearance up there?????
And then ask yourself is it worth retrieval? What will it tell you that you don't already know?
my 79 was under a strap too..i wound up taking pics and i could not get glue off..there was one in the strut adjustment bar too..you can also order invoice from gm
i would replace your fuel lines and drop tank
https://www.corvetteforum.com/forums...e-on-road.html
Well, My mufflers are off for upgrade and I did get the corner of the tank lowered. Then the tank shifted and closed off where my hand needed to go
After an hour of wrestling a full tank back up and into position, I decided to wait. I did in fact get the top right corner of the sheet out with one last effort and it has the last 6 of the vin on it. I'm saving it for the rest of the page. as I don't want to tear it all apart. I will drop the tank when I run it empty. Leave my spare tire off and live "on the edge" for a bit.The car is a 79 L82 4sp in dark green. Low number (under 2500 Dk green) production so I do want the sheet. I already have the Invoice I ordered and its all stock and legit. Not that the 79's bring chrome bumper money but it's special to me. It's my second corvette in a total of 53 cars owned to date. A little more than one a year. AUTO ADD. This is the only one I'm able to get a build sheet on.
Beg, borrow or rent a BORESCOPE with camera and SD card.
Push Borescope under the rubber gas tank catch flap (under the lid)
TAKE A PICTURE OF IT!
Better than removing it. (it may crumble to dust!)
"Hey! Its STILL got the original in the original position!"
Unkahal
