I am working on the rear suspension on my 82 and I recently pulled the spare tire hub. I just happen to look up and I saw a piece of paper and realized that is my build sheet hanging down! I tried pulling it down but its hung up on something and just started ripping when I pulled. I was able to read a small corner which just has a few meaningless codes. I'll just leave it there until I have to pull the tank for some reason.
Pulled this out today from a 77. I had to pull the driver side dash pad out and this was in the wiring harness. Flattened it out and it looks pretty good. You might want to check the dash pad if this is important to you
Found mine when o took the gas tank out. Was in good shape but I had to be careful dusting it off. I was able to find out what dealer ordered it. It is out of Pennsylvania and found pictures of the dealer before it went out of business. The Corvette Corner. Anyone know any vetted from there?
I just tried getting mine out yesterday. I dropped the tank a little to reach up. Mufflers ore already out. I got a good angle from going up where the antennae is. But the sheet has a glue splot holding it in place.
First I heard of them in dash though.....
All cars got the sticker on the gas tank. Only a few got them in additional locations like under carpet, in trailing arm pocket, stuffed behind dash, etc.
