need wiper bracket
Jan 8, 2022 | 09:52 AM
need wiper bracket
Does anyone know where I can get the wiper bracket in attached drawing without buying entire wiper assembly? Thanks for help.
Jan 8, 2022 | 10:23 AM
Jan 8, 2022 | 03:32 PM
Jan 8, 2022 | 07:46 PM
Army
That is not a bracket, that is one end of the whole wiper mechanism assembly. Lou.
Jan 8, 2022 | 07:52 PM
Lou, thanks for reply. Is that "piece" removable from the horizontal pieces that connect to the opposite side of car?
Jan 8, 2022 | 09:32 PM
Only by drilling out the rivets.
Jan 8, 2022 | 09:34 PM
Jan 9, 2022 | 08:17 AM
2016 C3 of Year Finalist
not mine, just found it for you
https://www.ebay.com/itm/31377361369...4AAOSwIS1hpVb1
Cheapest assembly on ebay I could find. Take what you need and relist the rest to get some money back.
Jan 9, 2022 | 11:04 AM
Original GM part number is 3953000 only came as an entire assembly.
Jan 9, 2022 | 11:27 AM
Army
If you look closely, one steel lever on each end on the outside of the bracket is welded to the rod. So you cannot just slip the end assembly off of the rod. Those bracket pieces are aluminum, I believe, and could be welded by a very knowledgeable welder...maybe! But getting them straight would be very hard with such small pieces. Lou.
