Hurst shifter
Old Jan 11, 2022 | 06:57 PM
1973bluevettee's Avatar
1973bluevettee
Default Hurst shifter
I bought hurst super shifter linkage and shifter 1969-79 for my Muncie 4 speed and the linkage came with a spacer block to go in between the shifter handle and the body, am I supposed to use this does anyone have any experience with this? And does anyone know of any good videos walking through how to put this linkage on because the instructions that came with my order sucks and I’m struggling.
Old Jan 11, 2022 | 08:07 PM
forman's Avatar
forman
how many spacers did they give you if you dont use them you wont get it into reverse
Im pretty sure theres one the thickness of the shifter flat part thats the one Im using the bolts that were on it were a little to short so I used others that were a little longer
Old Jan 11, 2022 | 08:13 PM
1973bluevettee
-ah ok so that’s what it’s for, it’s one spacer about 0.4 inches thick
Old Jan 11, 2022 | 08:21 PM
forman's Avatar
forman
yes thats what I have if you dont use it the shifter will rest all the way to the right ,, I used the retro shifter that looks like original one but you dont have to pull up to get it in reverse ,, dont use the hurst reverse switch its a nightmare to install you can use the one thats on the car already
Old Jan 11, 2022 | 08:23 PM
forman's Avatar
forman
Its a tighter shift and alot smoother
Old Jan 11, 2022 | 08:25 PM
1973bluevettee
-I also have the hurst shifter that you don’t have to pull up, so you used a spacer right
Old Jan 11, 2022 | 10:12 PM
forman's Avatar
forman
Yes it should only go in one way
Old Jan 12, 2022 | 04:07 PM
sunflower 1972's Avatar
sunflower 1972
Like this, right?
Old Jan 12, 2022 | 04:11 PM
bluthundr's Avatar
bluthundr
I just smacked a brass (I think 5/16) nut down inside my original shifter ball with a punch and screwed it on the Hurst shifter
Old Jan 12, 2022 | 04:33 PM
forman's Avatar
forman
Yes you still use the spacer with the shifter
Old Jan 12, 2022 | 04:39 PM
forman's Avatar
forman
They must be cheating out on that shifter mine still had the pull mechanism so it you were in the car you would never know it wasn’t the real shifter
Old Jan 12, 2022 | 04:57 PM
sunflower 1972
https://www.corvetteforum.com/forums...rome-****.html
Old Jan 12, 2022 | 07:01 PM
blue427's Avatar
blue427
go to 5speed.com for instructions
To Hurst shifter
