Stop light problem solved
Old Jan 13, 2022 | 06:23 AM
Landmark1234's Avatar
Landmark1234
Default Stop light problem solved
Stop light problem solved, turns out there was a bad connection on the wire harness coming down from the steering column.(exiting the bottom of the steering column)
nothing wrong with the turn signal switch everything operates stop light signal lights running lights.
thank you all for giving me leads to check
Old Jan 13, 2022 | 02:34 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
It's usually better to post this type of update in the original thread instead of starting a completely new one, which has no reference to the problem. If someone searches and finds the old thread, there is no resolution.
