Did I mess something up?
Old Jan 21, 2022 | 03:32 PM
Jd21476's Avatar
Jd21476
Default Did I mess something up?
I have a brand new 383 Stroker with and MSD ignition in my 1968. It was broken in a on a dyno and I have put about 1,000 miles on it since. She runs really good and strong but today I was pulling out onto my main street near my house and did a strong pull in 1st and 2nd gear to just short of redline. I looked in the rear view mirror and noticed a big puff of white smoke come out of my right side pipe and when I pulled up to a traffic light about 1/4 mile away the car was running rough and almost died. I kept revving the gas a little and she seemed to come back alive and then ran fine without any issues for the 25 miles to work. Is there anything I should look at or any issues you think it may have?
Old Jan 21, 2022 | 04:16 PM
L-46man's Avatar
L-46man
White smoke is Anti-freeze/water (vapor)
Blue smoke is oil burning
Black smoke..waaay too rich or someone slipped a diesel in there overnite.
Try this test (old school mechanics 101)
Car in driveway. E brake on!
Warm engine;
Rev car to 3000 rpm and keep it there for a minute. (low vacuum)
At one minute ABRUPTLY remove foot from accel pedal. HIGH VACUUM
IMMEDIATELY as it comes back to idle, Jump on the throttle abruptly BACK to 3000 RPM for one second. LOW VACUUM
LOOK AT THE TAIL PIPES (or have a trusted mechanical friend stand behind car) SOME COLOR COULD BELCH OUT OF THE PIPES.....
If nothing happens all is good!
REPORT FINDINGS.
This test tells you if you have a bad head gasket, leaking head bolts, bad rings (not seated yet), bad valve guides, mal adjusted carb etc.
good luck
Unkahal
Old Jan 21, 2022 | 04:21 PM
Jd21476's Avatar
Jd21476
I recently pressure tested the radiator up to about 18 psi and it held for over 3 hours so I dont think its a blown head gasket.
I tend to think its running either too lean or too rich because if I start it in the garage (with the garage door open) I have to walk out because my eyes and throat start to burn after a minute or two.
Old Jan 21, 2022 | 04:43 PM
L-46man's Avatar
L-46man
So it was black smoke you saw...probably either incorrect jets (non M4MV) or incorrect float level.
Tuning a Rochester quickly;
Turn idle stop screws in while car is warm and running
Turn one at a time IN until lean stumble (you'll hear it and feel it) Back out 1/4 turn
Do the other one same way
Drive!
Unkahal
Old Jan 21, 2022 | 04:44 PM
Jd21476's Avatar
Jd21476
No it was definitely white smoke. I'm running a Holley double pumper 750 cfm.
Old Jan 21, 2022 | 04:56 PM
L-46man's Avatar
L-46man
Was it very humid that day????
Sh!tty gas with water in it?
Unk
Old Jan 21, 2022 | 05:09 PM
Jd21476's Avatar
Jd21476
Maybe shitty gas. Its San Diego so its never really humid
Old Jan 21, 2022 | 05:31 PM
interpon's Avatar
interpon
Got a warranty?
if driving ok drive the snot out of it and keep close eye on fluids..
when bored, pull plugs and read..
tire smoke?
Old Jan 21, 2022 | 05:35 PM
Jd21476's Avatar
Jd21476
Oh, I never thought of tire smoke!!! Actually it may have been
Old Jan 21, 2022 | 09:26 PM
bluthundr's Avatar
bluthundr
Could be tire smoke and it hiccuped because you sloshed all the gas into the back of the bowl away from the main jets. Pick up a set of extensions if it keeps happening.
Old Jan 21, 2022 | 09:36 PM
Jd21476's Avatar
Jd21476
I was thinking about the tire smoke but the car didnt seem to get out of line. The gas sloshing in the bowl could be why it was running rough at the light. Thanks for the help. But…what is an extension?
Old Jan 22, 2022 | 07:46 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
burning eyes is too lean
Old Jan 22, 2022 | 07:52 AM
Rescue Rogers
Hes referring to Jet extensions. they extend the jet orafice into the center f the float bowl so that high G acceleration and decelleration waves in the fuel doesnt starve your carb metering block of fuel. It looks like a brass straw that the jet screws into or it could be plactic tube that slips over the jet
https://www.racingjunk.com/news/back...nsions-slide-1
Old Jan 22, 2022 | 07:56 AM
Rescue Rogers
https://www.summitracing.com/search?...et%20extension
Old Jan 22, 2022 | 11:31 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Or too rich.
Old Jan 22, 2022 | 01:16 PM
OldCarBum's Avatar
OldCarBum
How long did you warm it up before you blasted down the street at near redline?
Could simply be that the engine was still cold and the choke was still open, then your mashing on the go fast pedal.
The plugs could have been wet from too much fuel and it took a little time to clean them off.
Unlike engines with electronic fuel injection, carbureted engines need to be throughly warmed up before running them hard.
The white smoke you saw, could have simply been condensation steaming out of the exhaust.
If it’s been running fine and it is now, leave it alone, especially if it was professionally tuned on a dyno.
To Did I mess something up?
