wheel trim ring repair/replacement
Old Jan 31, 2022 | 03:16 PM
delandjohn's Avatar
delandjohn
Default wheel trim ring repair/replacement
Recently acquired 1972. Attachment clips on the stainless wheel trim rings and bent/distorted and do not attach to rim. Very tough spring steel. Solution?? 1) new rings? 2) replace clips? 3) repair clips somehow? ADVICE????
Old Feb 2, 2022 | 11:44 AM
boat196's Avatar
boat196
If it’s an original style trim ring with four clips. I believe it’s really difficult to change out the clips. You might look up georickproducts, he restores trim rings and sells them on flea bay. He would offer the best advice.
Old Feb 2, 2022 | 02:50 PM
Hopper12's Avatar
Hopper12
Hey delandjohn, not sure if this is impacting anything in your case, but be aware that if you have larger than 'stock' tires on stock rims, it can make these crazy clips even harder to install.
Old Feb 2, 2022 | 09:23 PM
delandjohn's Avatar
delandjohn
Thanks for the replys from all. Found some new rings for sale from Zip. Currently on back order but should be here in 2-3 months.
To wheel trim ring repair/replacement
