Hood won't open
Old Feb 4, 2022 | 06:37 PM
joescvette's Avatar
joescvette
Default Hood won't open
69 corvette hood latch on driver's side won't open. passenger side opened. Cable good didn't break. I tried everything any suggestions? Thanks
Old Feb 4, 2022 | 07:02 PM
69L88's Avatar
69L88
There are several YouTube videos on this topic. Search “C3 Corvette Hood won’t open”
Old Feb 4, 2022 | 08:12 PM
4corvettes's Avatar
4corvettes
You should be able to push a rod up through the fender louvers or from under the splash shield. You may have to remove the splash shield. Try to push up on the latch mechanism lever with the rod. If you get it, the hood will release. Good luck.
Old Feb 4, 2022 | 09:32 PM
joescvette's Avatar
joescvette
Thanks for the reply, I been on this for two days now. Getting worried
Old Feb 4, 2022 | 11:11 PM
How Are You's Avatar
How Are You
Don't worry. It's possible, just be patient.
Old Feb 5, 2022 | 08:21 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
is it on the ground or in the air? IF the passenger side popped thats good news because the drivers side has to move to pop the passenger side. I would have someone pull the hood release and hold it while you slowly jack the car up under the frame below that hood pin to see if its bound. iF its in the air put it back on the ground and try it again. It is just bound up for some reason or your pin is out of alignment. Or try getting your fingers under the hood on the passenger side and push towards the driver side while a third person pushes down on the bound pin side and releases it while the hood release is being pulled. You definitely will need help on this one
Old Feb 5, 2022 | 09:42 AM
JMH's Avatar
JMH
I saw a video on youtube about this. If you jack the car up you can reach up and release it manually I think it was "Corvette Ben "
John
Old Feb 5, 2022 | 12:15 PM
joescvette's Avatar
joescvette
That was a different year has a different lock. You pull down on it to open. Mine you have to push towards the front of the car. I was trying to a just the driver's side,and when I close it, I pulled the handle in side the car, and all it does is go back and fourth. It misses the lever on the hood. I have a big gap between the hood and the fender the driver side, I think that's why the lever misses the lock mechanism. The passenger's side I never closed. I'm going to try and loosen the front hingers, and see what happens. thanks for all your help. Not going well so far. I already chipped the paint on the hood . Night mare.
Old Feb 5, 2022 | 12:17 PM
John 65's Avatar
John 65
My 68 had this notch, 69 probably does too. Its in line with the release. I unscrewed and removed the wiper grill then stuck a long thin screwdriver in there to pop it.
Old Feb 5, 2022 | 12:23 PM
joescvette's Avatar
joescvette
I have the same lock, where did you put the screwdriver thru, there's no room
Old Feb 5, 2022 | 12:27 PM
John 65's Avatar
John 65
Sorry, cant recall, it was over 10 years ago but I definitely remember removing the grille and finding the area for that notch. Exactly where I dont recall but looks like from the pic you may be able to find it a few inches in from the edge.
Old Feb 5, 2022 | 12:34 PM
joescvette's Avatar
joescvette
Ok, John, thanks I'm leaving to try and pop the hood, here goes
Old Feb 5, 2022 | 12:47 PM
71 Green 454's Avatar
71 Green 454
Old Feb 5, 2022 | 06:53 PM
joescvette's Avatar
joescvette
4 corvettes thanks, I never through of going thru the fender louvers, it's OPEN! Thanks to everyone that helped me out. I can finally go to sleep. 2 1/2 days
Old Feb 5, 2022 | 06:55 PM
John 65's Avatar
John 65
Good news, very frustrating. Glad to hear it.
Old Feb 5, 2022 | 06:59 PM
joescvette's Avatar
joescvette
Old Feb 5, 2022 | 07:00 PM
Rescue Rogers
Old Feb 6, 2022 | 02:23 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Glad to hear you got it open. Now install emergency release cables. I would put up photos of mine but I have a 77 and they are totally different. A few how to threads on here over the years however. Very little money for a good insurance policy just in case.
Old Feb 6, 2022 | 09:20 AM
Big Block 69's Avatar
Big Block 69
As was said above, JMH, I think, If you jack the car up, I was able to reach straight up with my hand and unlatch the driver's side. There MAY have been a cover that needed to be removed to do this. I don't remember.
Rick
Big Block 69
To Hood won't open
