Tach issue on my 1981
Old Feb 19, 2022 | 11:00 AM
TO_Vette's Avatar
TO_Vette
Default Tach issue on my 1981
On my 1981, I replaced my intake manifold and had my carburetor rebuilt and now have a tach issue.
The car runs great but when my tach gets to 3,000 rpms, the tech gets all wonky and the tach starts bouncing all over.
Figuring that since a lot of wires were pulled, maybe something isn’t plugged in correctly.
IMG_0166.MOV
Where might I look?
Any ideas?
Old Feb 19, 2022 | 11:38 AM
cagotzmann's Avatar
cagotzmann
Attachment 48322999
Where might I look?
Any ideas?
The tach expects a nich clean square wave form based on RPM signal from the distributor . I am guessing there is now noise on the signal wire.
Do you still have the tach filter installed ?
1975-1989-corvette-tach-filter-installation.pdf (willcoxcorvette.com)
If the tach filter is still installed try running without. Also check connections to confirm clean connections.
Old Feb 19, 2022 | 11:45 AM
interpon's Avatar
interpon
Also try bypassing filter too..
otherwise I’m leaning tach board
Old Feb 19, 2022 | 01:56 PM
TO_Vette's Avatar
TO_Vette
The filter is still installed and connected.
When you say run without, do I just unplug it or run a wire to bypass it?
Old Feb 19, 2022 | 02:01 PM
cagotzmann's Avatar
cagotzmann
Follow this see item labeled #2
It may not reach as required so use a jump wire.
Old Feb 19, 2022 | 02:13 PM
TO_Vette's Avatar
TO_Vette
Default Found the problem.
Yes. Found it. I bypass the filter and the problem goes away. I'll order one today.
Thanks for all your help.
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Make sure the tach wire is fully plug into the distributor
To Tach issue on my 1981
