Ok,my recently purchased 1981,is original,so computer carburetor,which I’m thinking of putting a older model carb and distributor,and will also attempt to put on long tube headers,my ? Is if I understand correctly that the converter has a lock out on it,which I’m assuming is related to this computer,so if I swap the carb and distributor,how can you bypas the lock out. Thanks
Once it is disabled it acts like any pre-1981 TH350 trans......
But, as mentioned.....if you can make it work....you should.....it is worth a few MPG on the Highway......
Ok now I’m confused,lol...which isn’t hard,so has nothing to do with transmission converter,correct when it says converter,you’re talking Catalytic converter,if that’s the case,someone replaced the pipes years ago,so catalytic converters are gone.
