The transmission and overall condition of the car will make a big difference. I drove my 1979 L48 with a Camaro T5 from Utah to SoCal and averaged 19.5 mpg for the trip. Stock tire size, 3.55 rear gears. The carb and ignition were properly adjusted, alignment was good, brakes were not dragging, etc. I don't think I could get much better MPG than that without going to EFI, and even then maybe only 5-10% better.
I did the same trip in C30 pickup with a TBI 350 and got an average of 6 mpg. The rear brakes were dragging just a tiny bit and it definitely needs a tune up, but that truck should get at least 12mpg if it was working properly...
If your car is stock and reasonably well maintained I would expect at least 12 mpg with an auto.
Or 15+ with a manual, and a tiny bit better with an overdrive trans.
You might be surprised how much slippage occurs in a A/T even if it feels O.K.
A rebuild kit/clutches seals orings could really help if the trans has never been rebuilt.
The basic kit $200 to $300 (no sun gear-etc replacement if they arent sloppy) would pay for itself with gas prices climbing.
You could rebuild it yourself in one weekend/no experience needed...if you buy a rebuild softcover book w/stepbystep directions.
I'm thinking the 12 - 16 MPG answer was pretty much on line. I've had my 77 for a lot of years, and many of those it was bone stock. And that sounds about right.
Good news is that if you get rid of all the emissions junk, recurve the timing, tune/rebuild the carb and free up the exhaust it'll get around 22 MPG.
Not sure what rear gear your running, but I didn't get into the low 20's until I went with EFI. 4 speed, 3.36-1 rear gear.
And Automatics usually get worse.
Was 3.08 with a TH350 at the time.
I still get 18 Hwy with a 3.55, still Th350, and more than double the HP now.
A free breathing 76' Vette will get 17mpg as long as it has the 3.08 gear.......but it has to be performance tuned.....
The first thing you do is remove the miserable exhaust starting from the heads right on back.....
The cat has the same flow rate as a box of frozen peas and the mufflers aren't much better.
I have Corvette Central's 2 1/2" dual system with Magnaflows on mine and it really made a difference.
I did get 18 mpg once back in the day coming back from Colorado. And that was bone stock.
Maybe I had a tailwind......
Jebby
Yup. My stock '75 L-48 4 speed went from 15 mpg on the highway to 19/20 just by freeing up the exhaust.
Damn, I can get more MPGs out of a healthy Pontiac 455 lol
I'm surprised these cars struggled to break into the higher teens. Aerodynamic, somewhat lightweight, and a Q-Jet with tiny primaries. Oh well, nobody drives them for fuel efficiency anyway
