72 horn not working - need help troubleshooting
My new-to-me C3 has an inoperative horn, and I need some help troubleshooting.
I've read a lot of forum posts on the subject, but I'm new to the world of classic cars and need a more detailed description of how to assess the problem.
I've identified that my 72 has a single horn in between the headlights. I've located the horn relay under the hood, left fender.
When I compare the wiring at the relay to my docrebuild diagram it gets a bit confusing. I've attached some pictures of how it's connected.
Now, to test and isolate the problem:
I have 12V to the red wires at the relay. To test the horn itself, do I disconnect the green one at the relay and touch it against the reds?
What are the next steps, if the horn works that way?
It feels like the steering wheel button can't really be depressed, but I have no Corvette experience to compare it against.
Thanks in advance, you guys rock!
Tim
1973 with tilt/ tele
I followed this troubleshooting guide.
The horn works, when I ground the relay to the frame. This leads me to troubleshoot the steering column or wheel buttons.
There's nothing depressable on my steering wheel button.
I'll pull up some stuff on Wilcox as you recommended.
It explains the parts then covers how they work together. This is my 69 but should be similar to your 72.
That horn button is more complicated than it looks, gotta get everything aligned correctly.
I'm good with pictures too
So, started taking the pieces off.
Button and retainer look good.
There are no shims.
No horn contact piece. There was a bent piece of metal under the horn button...
I took of the hub nut, but will I need a puller to remove the hub from the column?
I want to inspect what's underneath so I can get the correct parts.
Confirm I can't fix this with just a contact piece, without pulling the hub?
Thanks!
Or can I order a replacement and just slide it in?
https://www.zip-corvette.com/67-82-h...ng-loaded.html
How do get to the stage of page 6?
Confused me the first time I started looking this up!
