Chevy 350
Old Mar 16, 2022 | 11:51 AM
nitan2k's Avatar
nitan2k
Default Chevy 350
I've always wondered this, whats the difference between the different chevy 350 small blocks, other than fuel delivery/intake method. As in, whats different about the blocks themselves? Are parts easily interchangeable between all chevy 350's around the same period?
Old Mar 16, 2022 | 03:44 PM
domenic tallarita's Avatar
domenic tallarita
I would say yes as I did a bunch. Stroke and larger crank journals than early 327's. Late 327 had large journal crank.
Dom
Old Mar 16, 2022 | 04:57 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
pretty much yes,
as mentioned, early blocks can have a smaller crank mains for small journaled crankshafts.
later engines have subtle changes in oil dipstick sides and rears seal changes.
latest vers have different heads with different manifolds and roller camshafts.
What are you looking at?
Old Mar 17, 2022 | 01:04 AM
nitan2k's Avatar
nitan2k
Originally Posted by calwldlife
pretty much yes,
Nothing in particular, just out of curiosity and incase I ever need to swap something. So how would I go about knowing if something from another 350 would fit mine? Is there a way to tell other than going out there and taking measurements?
Old Mar 17, 2022 | 06:02 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Most everything on a Gen1 Chev small block interchanges. There are 4 bolt main blocks. and 2 bolt main blocks.
The 4 bolt main blocks most consider to be the better of the two.
Just because it fits doesn't nessesary mean you want it however!
Corvettes have a specific waterpump, and other accessories. A lot of heads will fit. But you don't want them.
And the list go's on.
To Chevy 350
