Crate Engine Smoking
Old Mar 18, 2022 | 11:15 PM
RyanL's Avatar
RyanL
Default Crate Engine Smoking
Recently installed a Blueprint Engines 383, after going through the initial procedures prior to starting it.
Upon starting the engine everything appeared to be normal at idle speeds around 500 rpm, however when elevating the rpm to over ~1500 a white smoke would begin to puff from the exhaust.
Is this something I should be concerned about or is this expected for breaking in a new engine?
Old Mar 18, 2022 | 11:48 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Left?
Right?
Both exhausts?
Does the auto/transmission vacuum line to modulator have transmission fluid leaking into the hose?
Does the white smoke have a "sweet" smell (antifreeze-coolant)?
Old Mar 18, 2022 | 11:53 PM
RyanL's Avatar
RyanL
After letting it sit and starting it back up and ramping up to 2k rpm the right side began to smoke while the left side had no smoking. However I did not let it run long after I noticed the smoke on the right side, 15 seconds maybe
Old Mar 18, 2022 | 11:54 PM
RyanL's Avatar
RyanL
My sense of smell isn’t very good right now so I was unable to pick up on any strong smells of any kind.
Old Mar 19, 2022 | 12:08 AM
doorgunner's Avatar
doorgunner
Remove each spark plug on the right sideone at a time.....label each plug with maskin tape
R1
R2
R3
F4
Take a pic of the plugs side-by-side to determine if the cylinder head gasket is defective....post pictures.
Old Mar 19, 2022 | 03:33 AM
Giddy-up Go's Avatar
Giddy-up Go
Was previous engine burning oil? May be oil in the exhaust that is burning, and no problem with your new engine.. Happened on my 72 pickup during engine braeakin with the 327 I put in
Old Mar 19, 2022 | 08:46 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Pull plugs and inspect.....borrow a coolant pressure tester and pump the system......
If these both check out.....put it together and run the hell out of it....
Jebby
Old Mar 19, 2022 | 08:55 AM
derekderek's Avatar
derekderek
and watch your coolant level. use a fairly strong antifreeze mix. the smell of antifreeze out the exhaust is unmistakable. water don't smell at all...
Old Mar 19, 2022 | 09:00 AM
Purple92's Avatar
Purple92
As other posts have indicates - white smoke is typically coolant / anti-freeze.
Get the engine warm (not hot - but say 160 - 180) and do a cooling system pressure test.
Old Mar 19, 2022 | 09:28 AM
Jeffs82c3's Avatar
Jeffs82c3
White smoke can also form from automatic transmission fluid, but if it’s only smoking on one side I would guess a head gasket or a intake gasket. Good luck
Old Mar 19, 2022 | 11:08 AM
RyanL's Avatar
RyanL
The previous engine did have a piston failure on the right side which could be the reason it’s smoking. And there may have been a slight amount of water in the mufflers from sitting out.
I may also pull the plugs later
Old Mar 19, 2022 | 02:29 PM
ddawson's Avatar
ddawson
Could also be the intake manifold gasket. Worth taking a look there to after checking the plugs.
Old Mar 19, 2022 | 02:47 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
whatever it is it shouldn't be.
what did you actually get from the builder?
short block? long block?
To Crate Engine Smoking
