Turn signal issue
Old Mar 20, 2022 | 06:04 PM
AdamR4343's Avatar
AdamR4343
8th Gear
Default Turn signal issue
1980 Corvette Alrighty, I’ll try to describe what is going on more clearly this time. My left turn signal is blinking much slower than the right turn signal. The warning flashers blink at the same rate. All bulbs work and have dielectric grease on them. I have not been able to find where the ground wires are? I changed the flasher relay at the fuse box too. Thanks for any feed back!
Old Mar 20, 2022 | 08:46 PM
kodpkd's Avatar
kodpkd
You put dielectric grease on the bulb contact points? Dielectric grease should never be put on electrical contact points. If it is on the rubber to seal the bulb,,, that's what it's designed for.
