1973 Transmission leak
Old Mar 21, 2022 | 08:14 PM
ConnorBeaton1973's Avatar
ConnorBeaton1973
Default 1973 Transmission leak
Hello everyone,
About last week, I noticed oil on my garage floor. It looks like its coming from the transmission. Any common reason why? What to look for?
Old Mar 21, 2022 | 09:23 PM
Mooser's Avatar
Mooser
Oil (black or amber) or automatic trans fluid (red) or gear oil (standard, also black)
How long since the car started or moved?
M
Old Mar 23, 2022 | 03:33 PM
Mooser's Avatar
Mooser
Guess it's ok now
M
Old Mar 31, 2022 | 06:59 AM
ConnorBeaton1973
Hey M, sorry for the delayed response. The oil color is brown and the car hasn't moved/started in about 3 weeks. I haven't crawled underneath the car yet but it looks like its coming from the area of where the firewall is. Transmission is full of oil. Maybe a seal?
Old Mar 31, 2022 | 07:06 AM
Bikespace's Avatar
Bikespace
Rear main seal? Automatic or manual?
A photo or three would help, even if you just hold your phone under the car (with some light).
Old Mar 31, 2022 | 07:20 AM
Mooser's Avatar
Mooser
Brown would sound more like motor oil as the trans fluid if pretty red (or should be)
How much are you seeing on the floor? a tiny amount of oil can make a big puddle...
If it's not a huge puddle (like a dessert plate type of thing) and the car hasn't started or moved in a while I wouldn't be too concerned right away, some of the seals (rear main) will sort of dry out and shrink a little and might let some oil seep by after time (and then others can sit for years without issue) but once the car starts and moves a bit everything goes back to normal.
OR
its one of the major seals and it's going to be a big deal to change
So hope for the cheap one first and worry about the expensive one when you're sure
M
To 1973 Transmission leak
