I recently decided to rebuild the rear suspension on my 73 4sp coupe. What caused me to make the leap was a sudden loud clicking noise emitting from the driver side rear bearing and an apparent missing c-clip on the driver side side yoke causing the yoke to pull out of the differential when the suspension was unloaded. The guy who rebuilt my arms said that the driver side unit was missing some essential components when he disassembled it, namely, there was no spacer or shim! He rebuilds trailing arms every day for years and says he’s never seen this before. The history of the car prior to me purchasing it is undocumented but my forensic investigations tells me that the arm or arms had been serviced sometime in the last 49 years. Mostly because the rubber in the front bushings wasn’t blown out and the bolts had antiseize on them. The outside of the arms have plenty of surface rust, paint and grease/dirt buildup on them as evidence they’ve been on there for a looong time. The car has 116K miles on it, 5K of which we’re put on by me.
Have any of you ever seen or heard of a trailing arm being rebuilt without the spacer and shim? I dont understand how this came to be.
Thanks in advance for any responses.
Ken
Axles with undersize journals- either from the bearing spinning or someone polishing them for slip bearings.
Axles with threads mushroomed over and the nut forced on stripping the remaining threads
Axles with cheap wheel studs
Rubber bushings not compressed and staked
Arms bent by an alignment guy or home hack
Caliper brackets bent by using the tools many sell today
Rotors undersize
Rotted arms that were welded, creating welded, rotted, junk
Parking brake shoes held on with hardware shoe springs and sheet metal screws
Chinese bearings, cheap no name brand junk but the local chain store had them for $5 less than a quality USA or Japanese bearing
Wrong caliper bracket bolts that scored the rotors
new SS parking brake hardware that is just stamped out and not correctly fit- I deal with this all the time
Bent support legs from hammering on seized shock mounts
I lot of these things came from car owners, local garages, dealerships and yes even corvette shops. Welcome to my world. I have pictures of all or most of all those things in my files.
The diff axle doesn't use a c-clip, they are snap rings and usually they don't fall off.
Typical reasons are:
They are incorrectly installed
Are the worn size
Rebuilt axles were used and the groove not machined correctly.
The worst is the axle faces worn down to that point and the ring fell off, that is over 3/16 of powdered metal floating in the diff and once the axle wears enough will crash into the housing and grind into it. I hope yours is not l like that and I hope you have good arms set up now.
Thanks for chiming in Gary. I’ve read a lot of your stuff both here and on Digital and really appreciate the education. I used that knowledge to quiz prospective rebuilders. Last time I went through this exercise was 40 years ago on a 69 coupe and swore I’d never get myself into this situation again, and only allow myself to buy cars that have already had this work done. I’m confident that my stuff has now been corrected and look forward to driving it again by weeks end.
BTW my side yoke was fine, the snap ring had fallen off, not sure whether it was incorrectly installed or defective. The diff had obviously been worked on before as it has a drain plug in the bottom. Other than that it looked great inside and really clean.
The shocking thing I found was the old mouse nest that came out when I was beating on the spindle. Thankfully Fievel was long gone but he left some pink insulation and a stash of rice.
