wiper problem
Old Apr 22, 2022 | 04:14 PM
delandjohn's Avatar
delandjohn
Default wiper problem
Wipers don't work. Door cover opens and then nothing. 72 454. Has new wiper motor (bench tested) and fuse is good. Any ideas on most probable cause? Where do I start? Thanks for input.
Old Apr 22, 2022 | 04:39 PM
Mooser's Avatar
Mooser
Did it work before or ???
Check for power going to the switch for the door opening and check for power on the other side with the switch triggered.
This switch, if there is power going into the switch then check to see if it goes through when the switch is activated by the door, if it doesn't get power through, try tripping the switch manually with a screwdriver or something, if it works manually you might need to adjust that stop bolt to be a bit farther in.
If there's power through that switch then it's a problem at the motor, double check the ground and the power wire.
Also make sure the switch in the dash is grounded, frequently that's an issue
M
Old Apr 22, 2022 | 06:44 PM
delandjohn's Avatar
delandjohn
Thanks for the input. Don't know history. Recently bought car. File has receipt for new wiper motor and says "bench tested before shipping". Will follow your advice.
Old Apr 22, 2022 | 06:57 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Is the wiper override switch under the steering column turned on
Old Apr 22, 2022 | 07:07 PM
Mooser's Avatar
Mooser
That's an excellent point, always check the obvious first
M
Old Apr 22, 2022 | 07:42 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
go to Willox and check there troubleshooting tree for your 72
read through all these
Old Apr 22, 2022 | 08:17 PM
71 Green 454's Avatar
71 Green 454
M
My wipers only failed to work one time, I checked for power at the switch posted by Mooser and had "No Power". I knew I had the override switch in the correct position. I removed the override switch and I had power on the feed side, but none on the side going to the door open switch. It turned out that the contacts in the override switch were dirty. I took it part, cleaned the contacts and that fixed the problem.
Good luck.
Old Apr 22, 2022 | 08:18 PM
delandjohn's Avatar
delandjohn
Good question. Will check.
To wiper problem
