Electrical problems
Old May 1, 2022 | 12:51 PM
TastyFlamingo's Avatar
TastyFlamingo
Cruising
Default Electrical problems
Hey everyone,
I wanted to see if anyone is aware of or has experienced this problem. This season when I was changing the oil and pumping the tires up after taking my ‘76 out of storage, I noticed some electrical problems. The passenger power window wouldn’t go down, the dash light bulbs don’t light up (signal lights work, just the general backlight/bulb to light speedometer), and the signal lights on the back and front don’t work while I’m in gear, unless I have my foot on the breaks.
Having all these problems occur at the same time, I wonder if a fuse has possibly went and a common electrical circuit was effected, but I know next to nothing about vehicle electrical. Is there an obvious problem here? I live in AB Canada and it got to -45°C (-49F°) some days of the winter, though the vehicle was stored in an attached semi-insulated garage (no heat other than attached house heating, but no connection to furnace like the rest of the house).
thanks in advance to anyone reading and replying!
Old May 1, 2022 | 01:11 PM
Peterbuilt's Avatar
Peterbuilt
Default WOW! That's cold.
Let's start here:
Check that the fuses have power on both sides as it sounds like you might have corrosion on the terminals that hold the fuses.
With the headlight switch pulled out check the instrument fuse on both sides.
Old May 1, 2022 | 07:24 PM
TastyFlamingo
Cruising
Originally Posted by Peterbuilt
Let's start here:
thanks I’ll give this a shot. Where would I be without people like you on this forum
Old May 2, 2022 | 04:41 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Ahhhh, sounds like ground problems to me.
Old May 2, 2022 | 04:46 AM
Fly skids up!'s Avatar
Fly skids up!
You description of the symptoms are a little vague so I'm going to take a guess. It sounds like the signal light but don't flash, right? At those temperature I would bet that the alternator belt is slipping and you have a low voltage situation.
To Electrical problems
