C3 frame interchangeable with C2 frame?
Old May 1, 2022 | 02:24 PM
20mercury's Avatar
20mercury
Default C3 frame interchangeable with C2 frame?
Saw this ad for an early 68 frame without the kickup braces that were added on late 68 and 69+ frames and seller says it is interchangeable with C2 frames.
1968 corvette early frame - auto parts - by owner - vehicle... (craigslist.org)
I know 68 frames had a different radiator support setup than 69+, and I had heard that C3 frames were similar to C2 frames, but is an early 68 frame really interchangeable with a C2 frame?
Old May 1, 2022 | 06:31 PM
loup68's Avatar
loup68
Army
The rear of the frame on a C-2 is totally different. Check pistures. Also all of the body mounts have to be different. The 68 front frame horns may be different also. Lou.
Old May 1, 2022 | 08:24 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
http://repairs.willcoxcorvette.com/1...mension-chart/
the tails are different from the c2 to c3.
the 68 to 72 are different from the rest of the c3s in the tails as well as the body mount heights.
You might be able to make it work for a 68
Old May 1, 2022 | 09:29 PM
Tiger Joe's Avatar
Tiger Joe
Not a drop in replacement but not impossible.
there a few c2s running around on a c3 frame.
Old May 2, 2022 | 06:15 AM
Mr D.'s Avatar
Mr D.
Common practice to take a C3 frame and graft the rear of a C2 frame onto it. I would personally prefer to not go that route but sometimes you got to do that if no C2 frame is available, or your budget doesn't support a good used C2 frame. I think the C3 frame needs to be 68 to 74, could be wrong on that.
Old May 2, 2022 | 08:16 AM
derekderek's Avatar
derekderek
i believe every body mount needs to be raised or lowered to put different era body on either frame.
Old May 2, 2022 | 11:51 AM
20mercury's Avatar
20mercury
Good info and thanks for the responses.
Old May 2, 2022 | 01:28 PM
derekderek's Avatar
derekderek
if you have a c2, it may be worth the trouble. and if purists don't like the kickups, tell em to get the hell out from under your car...
Old May 2, 2022 | 07:37 PM
loup68's Avatar
loup68
Army
Looking at a C-2 frame drawing, I could swear that the #2 body mount location is back further than on a C-3. Lou.
Old May 2, 2022 | 08:34 PM
kodpkd's Avatar
kodpkd
Going to the trouble of putting a different/new frame on your car and you are looking at a rusted one?
Old May 2, 2022 | 08:48 PM
derekderek's Avatar
derekderek
first you drop body on, stand back and look and measure. then you stack big washers on the mounts that are supposed to be higher. then you see how far off some mounts are when it is sitting on other mounts. if Lou is right it should sit ok on the other 3 and give you a measurement to offset #2. then compare the measurement you got to what the book says. then you decide if you are gonna resell the frame or start modding it. edit: i looked at the ad. i don't see 3k value in that frame if it is the correct week 68 you want it for. i assume you have a mid year needs a frame?
Old May 2, 2022 | 09:17 PM
derekderek's Avatar
derekderek
74 frame. plus a few parts. https://www.copart.com/lot/54298130/...fl-tallahassee tallahassee
Old May 2, 2022 | 11:30 PM
20mercury's Avatar
20mercury
Thanks for the leads, but no, I already have good frames for what I need now. I was just surprised that the seller claimed this early 68 frame was interchangeable with the C2 frame. I had been told that they were similar but I did not know they were interchangeable. Much thanks for all the educational responses and good to know you could make the C3 frame work with a C2 with some mod's if you had to as a last resort.
To C3 frame interchangeable with C2 frame?
