Manual swap linkage question.
Old May 10, 2022 | 11:00 AM
Joshua Ruiz's Avatar
Joshua Ruiz
Default Manual swap linkage question.
Hello recently I got a 1968 Muncie m20 for a my manual swap and was wondering about which year linkage I would need to buy for it. Also I have a 76 if that helps any.( I know they changed the trans to a t-10 but wasn’t sure if getting linkage from 74-76 years would work with the 68 Muncie) thanks in advance.
Old May 11, 2022 | 08:33 AM
stingr69's Avatar
stingr69
Your '68 transmission has levers that use a nut to retain them. The '69 and up use a bolt to retain the levers. The levers are not interchangeable so you need '68 levers for sure.
Old May 11, 2022 | 12:22 PM
Joshua Ruiz
Thanks I’ll get some on order then thanks for saving me from finding out the hard way
To Manual swap linkage question.
