Body Dolly for 76 vette
Old May 25, 2022 | 04:55 PM
Gmchev's Avatar
Gmchev
4th Gear
Default Body Dolly for 76 vette
Hey there, chasing dolly specs on building for my vette thanks for any help
Old May 25, 2022 | 09:19 PM
69L88's Avatar
69L88
Pretty simple. Essentially a platform for the body to rest on with an “outrigger” to support the front. Use 2x6s as you’re supporting roughly 800 lbs.
Old May 26, 2022 | 12:22 AM
Bikespace's Avatar
Bikespace
Try this thread.
https://www.corvetteforum.com/forums...ley-plans.html
Old May 26, 2022 | 05:46 PM
MLM7447's Avatar
MLM7447
I just winged mine based on length/width measurements of the chassis.
made out of 4x4’s and 2x6’s. With casters from HF and purchasing the wood from HD, the thing still tips the scales right at $300.00.
Missing from the pic are the risers that got added once the body was sitting on some cross bars that I put there temporarily to hold it at the height I wanted it. I put the risers at all body mount points.
However much it weighs with the body on top, I was able to push it up the hill between garages in my driveway w/my son tuggin’ and me pushin’. At the height it’s at, I have access to the underside, and a fairly clear path to being able to get the greasy pig clean underneath, but it puts the roof at about the 6’ high level.
Old May 27, 2022 | 01:54 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Here's the link to my short thread about a tall body dolly to allow easier access to the underside of the body. Measurements (imperial not metric) are in post #3.
https://www.corvetteforum.com/forums...ody-dolly.html
I answered your PM, but now I see you have a '76. Mine is a '71, so the measurements might change a bit - be sure to verify them for your project.
Good luck!
Paul
Old May 29, 2022 | 12:22 PM
hdz28's Avatar
hdz28
I just measured up the body mount points and replicated that on a wooden frame with casters on it, sorry, no pics. One thing I would caution is to make sure you support the nose, also, the bonded joint at the firewall will stress over time if the nose is hanging. I put an outrigger from the chassis buck out to the radiator support.
Old May 30, 2022 | 03:11 PM
caskiguy's Avatar
caskiguy
From Alan71'
Old May 30, 2022 | 07:56 PM
boat196's Avatar
boat196
Originally Posted by caskiguy
From Alan71'
I used that dolly during my restoration, I found it to be extremely sturdy. I also added 8” pneumatic wheels and a support for the radiator/ nose.
Old Jul 4, 2022 | 04:22 PM
OldCarBum's Avatar
OldCarBum
Exactly what I was looking for.
Alan did an update to his original design where he added the front support under the radiator.
I guess I can figure that out on my own.
Thanks!
To Body Dolly for 76 vette
