Replacing upper ball joints, what size bolts?
Old May 27, 2022 | 10:46 PM
Steve Stroman's Avatar
Steve Stroman
Default Replacing upper ball joints, what size bolts?
As the title indicates, I'm replacing ball joints and my uppers came with rivets. I won't be using them prefer to bolt them in place instead.
What size bolts do I need? I know to get grade 8 but not sure of size and length. Thanks for any help!
Old May 27, 2022 | 11:52 PM
Bikespace's Avatar
Bikespace
Have you ordered the ball joints yet?
I'm pretty sure my ball joints came with the bolts. I may be mistaken, though. After photo:
Old May 30, 2022 | 12:42 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
It really helps if you mention your car's year and model when asking questions like this. However, I see in your profile that you have a '75
The MOOG replacement ball joints for my '71 coupe that I got from Rock Auto came with the bolts...
Best I can recall is that they were 1/4" x 1" or 1-1/4". The bolts come up from the bottom of the CA and there is room on the upper nut side if you want to get them a bit longer.
Is it too late to return yours with rivets and get others with the bolts included?
Old May 30, 2022 | 06:51 AM
derekderek's Avatar
derekderek
take the rivets to lowes or fastenal. use them to tell you what size shank. grade 5 fine thread. they wouldn't have riveted them if it needed something like grade 8. lowes has a better fastener section than home depot these days.
To Replacing upper ball joints, what size bolts?
