1978 Window and Power Lock Troubleshooting
Old Jun 1, 2022 | 12:56 AM
brasian's Avatar
brasian
Cruising
Default 1978 Window and Power Lock Troubleshooting
Hey guys,
My passenger window wasn't working so I ordered a whole new motor. It was stuck in the up position and the motor swap itself was pretty straight forward. However, after replacing the motor it's still not working. In the process, I also did something to my power locks and they aren't working now either. Here's where I'm at so far...
  • Pulled the old motor out
  • Verified I am getting 12V on both the tan and blue wires when the window switch is pushed in the up/down positions
    • The 12V is relative to the ground lug on the door panel that also connects to the power lock switch
  • Installed the new motor
    • Am I missing a rivet or bolt by my thumb? It looks like a hole on the regulator lines up with it if I push the motor forward.
  • Key in ACC position, driver window works as expected, passenger window still doesn't have any movement
    • When I press the up, the interior lights dim and there is a slight click
    • When I press down nothing happens
    • I also took the motor out and installed it without the gear to make sure nothing was binding. Motor still didn't run. Bad motor?
  • Verified the motor bolts have continuity to the door ground lug
  • Verified the door ground lug has continuity back to the negative battery terminal
  • The orange wire to the door lock switch is 12V. I put a jumper wire from that to the motor terminals one at a time to see if I could get the motor to move and still nothing. This is when my power locks died.
  • All fuses look good
    • I don't see a fuse labeled specifically for the power locks. Anyone know which one it is?
  • What does this connector go to? It has orange and green wires and I don't see anything it should mate to.
  • What am I missing?
    • Next I'm probably going to rip the motor back out and hook it up to a power supply to make sure it even works
Old Jun 1, 2022 | 05:25 AM
hunt4cleanair's Avatar
hunt4cleanair
The buzzer warning box is not being used and missing. the ora/grn wire connector plugs into the buzzer box. The buzzer is used for the following
  1. seat belt warning
  2. headlight warning
  3. ignition key/alarm warning
I suspect none of these ops are working. The connector routes to the driver's side door lock...probably why its not working. I'm attaching two pages from the 78 Electrical troubleshooting guide that relates to the buzzer warning box and a photo of the box and connector plugged in.
These boxes are a challenge to find and working. Some time back Wilcox was working on this unit and its electrical circuit board. The challenge was the buzzer that is soldered onto the board...the sound changed nearly each year so getting the right box, and working is a challenge.
Hope this helps!
Old Jun 1, 2022 | 06:57 AM
ukjohn's Avatar
ukjohn
Your problem with the window could be the switch, I found that although I was getting 12volts at the motor connector, the switch wasn't passing enough current to operate the motor. Run a large cable direct from the battery to the motor to check if that works, if it does then you can open up the switch and clean the contacts.
The door lock is powered through the CLK/LTR/CTSY fuse. This is 20amps rather than the window motor circuit breaker which is 30amps, so you might have blown this fuse.
Old Jun 1, 2022 | 04:10 PM
brasian's Avatar
brasian
Cruising
Good to know thanks! The power locks were working even with that connector as is. They only stopped after I tried to jump the window motor off the orange wire to the power locks.
That's basically what I did with the orange wire from the power locks. That goes to the 20A you are referring to. I'll double check tonight that the fuse isn't blown and I'm getting 12V to the orange wire. I'm going to pull the motor back out and hook it up to bench top supply to verify the motor runs on that. Will post back with an update.
To 1978 Window and Power Lock Troubleshooting
