Chemical Stripping Advice
This is my first post so I will try to keep it short, sweet, and fact filled. I need advice about the correct product and procedure to chemically strip the paint off two parts of two cars.
Car #1: My 71 Vette, which I just bought in February, was repainted once. The body looks like it was stripped and then covered in some type of yellow high-build product followed by a gray primer/sealer, Then it was coated with base/clear topcoat. When I test sanded a few spots the dust was white at first. Then after cutting through the topcoat I started to see some red dust..It's a red car. I hit the jambs with lacquer thinner and it removed some of the paint so I think they were never touched. The rest of the body panels did not react to the thinner at all. The yellow layer is very thick! At first I thought it was body filler, but it did not smell like it at all and I can see it on every panel.
Car #2: This one is a blue donor I bought since my red one needs a new nose. This one has many layers of paint that need to be removed, and if I'm right, it still has the original paint underneath all those layers.
Car #1: Clear coat; base; sealer; something; fiberglass?
Car #2 Donor Car; multiple layers; Red factory primer?
I've read many posts on this topic and sanding does not appeal to me at all. I will do enough sanding when it comes time to block it out. DUB, if you are out there I would love to get some advice from you, but being a new member I cannot contact you directly (which I understand and get).
About me: Corvettes are new to me, but working with cars is not. I've already fully restored a 67 Camaro and an 87 Silverado, but fiberglass, vacuum systems, and independent rear suspensions are new to me.
My Current Painting Plans: Strip to bare fiberglass, apply a high-build polyester product, let it cure, block it until it's smooth, seal it, topcoat, cut and buff.
Hope I provided enough information without boring you to death,
Thanks,
Mark
and put cardboard down where the stuff is gonna land. it is nasty and re-hardens. especially cover sidepipes. and practice on the half of the donor car that is not being used. are you doing your own paint? are you in 1/4 acre residential zoned house. if so, your neighbors will hate you forever and a town zoning guy will be by talking 2000 buck per day fines. how do i know? 5th baby!
Anybody know what that brown product might be?
Thanks again for the advice.
Mark
Not all chemical strippers are same and some are not that aggressive for polyester, so be sure to use a product that's been tested.
Like someone mentioned there is a lot of those in use in aerospace industry.
I did mine that way and can't be happier. Also I have heard of some folks having their car bodies thin as ping-pong ball from over sanding.
Regards
Matko
Regards
Matko
