I have a 72 Coupe, all original, and the radio ***** and **** on the light switch have become sticky. I had the exact same problem on an older Mercedes I had, and never was able to get them cleaned. Has anyone else had this problem? Before I start experimenting I thought I would check on the forum. Thanks.
plain old 70% rubbing alcohol is very handy, probably already in the house and cheap. I use it for a lot of things. Cleaned my sticky ‘69 wheel nicely. Careful the 90% will affect paint
I don't recall what I used on my sticky '72 steering wheel (maybe denatured alcohol), but had to do it a couple few times with day or so intervals before it became non-sticky. Been a couple years now and it's still good.
If you think it's the plastic going south, I got mine all looking new and shiney. I diped them in laquer thinner after they were clean.
At first I thought they were still wet, but NO, they were new again.
Dom
Originally Posted by sunflower 1972
I personally would not use lacquer thinner on any type of plastic.
I tend to agree against lacquer thinner but if it worked for you, I who am I to argue. For others reading this, be careful with acetone too - you may end up with a blob of plastic goo.
Works great, BUT I guess you need to know what your doing. Just a QUICK dip (in & out) and the thinner re-arranges the surface to a complete shine. BUT, I can keep that secret as I have done many with 100% beauty.
I may add that I was going to put black urathane on my A/C ducts and sprayed them with laquer thinner to get a good bond and didn't have to paint them as they came out great and looking new to this day.
Exposure to moisture causes a chemical reaction (hydrolyzing) that breaks the polymer down and
Exposure to heat which cause the plasticizers and lubricants used in the original formulation of the polymer to rise to the surface.
Both are irreversible. No amount of “cleaning”, irrespective of the cleaning medium, will stop either process. As others have posted, coating them is the only practical solution (unless, of course, you can replace them with new).
This topic came up at a car show at weekend when a mate asked one of the detailers on site to check out his C7 steering wheel that had become sticky. He said he was seeing this a lot recently and put it down to people using hand sanitiser due to Covid and advised to not touch any surface in the car until your hands were completely dry..
