Emergency Brake Question
Old Jul 3, 2022 | 02:10 PM
TO_Vette's Avatar
TO_Vette
Default Emergency Brake Question
Working on my emergency brake handle and needed to remove the spring to the cable under the car. This is the spring that goes right behind the adjustment nut.
Now I can't seem to figure out how to go about this correctly.
I can't seem to pull the spring enough to get on this nut and I can't tighten the nut enough to get close enough.
What am I missing here?
Old Jul 4, 2022 | 08:20 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I think I grabbed the right portion of the spring near the nut with vice-grip pliers.
Then I worked the spring out of the hole by using a twisting motion with the pliers.
It wasn't easy.
While you are under there try adjusting the E-brake shoes closer to the drums before reinstalling the spring.
Old Jul 4, 2022 | 10:13 PM
Bikespace's Avatar
Bikespace
It wasn't easy.
That sounds correct. Needle-nose vise grip pliers worked for me, too.
Wear eye protection when you do this.
Old Jul 5, 2022 | 10:40 AM
kansas123's Avatar
kansas123
It seems like I loosened the bracket that you can find following those cables back to the rear. Loosen, mind you, not remove. That'll create a whole new vocabulary........ Then don't forget to retighten after replacing the spring.
Old Jul 5, 2022 | 07:56 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I loosen mine then use the needlenose vise grips as well
To Emergency Brake Question
