Ac -?
Old Jul 3, 2022 | 10:12 PM
ScreamingEagle70's Avatar
ScreamingEagle70
Default Ac -?
HI GUYS Well its 90f out side and my ac was blowing 43 degree then slipping belt I replaced now my compressor will not come on.i put the gauges on and the low side is125 and high side is 125.what went wrong plus I put in the new poa valve eliminator that tell me to adjust the cycling switch to lower the low side but nothing happing and the compressor getting power did my original compressor **** the bed.1970 small block held vacuum ad all oil and a correct freon charge all I did was replaced the belt because it was slipping or was that the compressor was dying .is there a way to check out the compressor before buying one thanks for your help bob
Old Jul 4, 2022 | 12:09 AM
vairxpert's Avatar
vairxpert
Is the clutch energized and engaged?
Old Jul 4, 2022 | 09:13 PM
ScreamingEagle70
Allset thanks just a loose wire
To Ac -?
