Evapo-Rust
Old Jul 10, 2022 | 04:23 PM
Golferdad's Avatar
Golferdad
Default Evapo-Rust
I have used this stuff for years,and nothing compares to eating rust,you can buy it in most auto parts stores,and usually around here is $25-$30 a gallon,so kind of expensive but will definitely get rid of rust.
Old Jul 10, 2022 | 04:25 PM
Golferdad's Avatar
Golferdad
Great stuff
Old Jul 10, 2022 | 04:35 PM
Golferdad's Avatar
Golferdad
I have a gallon in a rubber tote,and put the transmission pan in,it’s been soaking over night
I didn’t take a before picture,this is what it looks like after one night,completely dissolved rust other than under the lip as you can see,and the whole pan was rusted like this.
So,will flip the pan over and let it soak till all the rust is removed.
The whole piece will look like the bottom,and paint it back black again.this stuff is terrific no work,just let it sit in evapo-rust.
Old Jul 10, 2022 | 05:40 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Thanks, just bought some on amazon for $10.49. Any tips?
Old Jul 10, 2022 | 07:02 PM
augiedoggy's Avatar
augiedoggy
harbor freight has it too
Old Jul 10, 2022 | 07:19 PM
Golferdad's Avatar
Golferdad
Yea,it’s better if it can just sit a day or so,and let work
Old Jul 10, 2022 | 07:22 PM
Golferdad's Avatar
Golferdad
Do you have liquid or paste type,never used the paste type,and it is best if at all possible to have the whole piece or part fully submerged in it,
Old Jul 11, 2022 | 09:30 AM
Tooch1's Avatar
Tooch1
I agree, this stuff really works well. I find that if you leave the part(s)soak a day or so, you get the best result (as someone mentioned above). Also, you can re-use it over and over again. At least 3-4 times before it starts to lose its effectiveness.
Been using it for quite a while now. Here's another before and after example on a 73-74 454 EGR Valve "Hold Down" bracket.
Before Evapo Rust!
After using Evapo Rust with a light coat of clear matte spray finish applied!
Old Jul 11, 2022 | 11:34 AM
gbvette62's Avatar
gbvette62
That stuff works great on cleaning out the element fins on old, used, original Casco lighter elements. If you have a crusty Casco 63 lighter for your 69 big block car, soak it in Evapo-Rust for a couple days, and it's NCRS ready.
Old Jul 11, 2022 | 12:04 PM
78VetteSuperFan's Avatar
78VetteSuperFan
There’s a paste version? Has anyone every used this? I’ve always had great luck with the liquid, but not great for stuff too big or hard to get to to soak
Old Jul 11, 2022 | 02:05 PM
grantstigers's Avatar
grantstigers
john
i bought the 5 gallon pail
lasted me a couple years and this is my third pail
but to prolong the evap rust
i would buy 5% vinegar and let it do all the dirty work then a final rust removal using evap
some clean parts with light rust use evap
i have rusted rims and I just used vinegar in a tub and use a steel brush and it takes off most heavy rust then stick in my bead blaster to give it a quick clean vs spending a lot of time blasting and wearing down the sand
i wouldn’t waste the evap rust in a tub to clean rims
evap will take off the patina if an item is plated and if it has ink markings from the factory
i accidentally left hose clamps for too long and evapo rust disintegrated the clamps
but let me know what you want to use the evap for and I can guide you
thanks
grant
Old Jul 11, 2022 | 03:03 PM
gdh's Avatar
gdh
Anyone try the gel version on those larger parts?
Old Jul 11, 2022 | 09:39 PM
Golferdad's Avatar
Golferdad
Never use the gel type,but doubt it would work as good as the liquid,but I love the liquid type.
Old Jul 11, 2022 | 10:51 PM
Mark G's Avatar
Mark G
Just curious, what's the active ingredient? Is it a phosphate-based solution?
There are other rust 'eaters' which are basically a phosphate solution.
Old Jul 12, 2022 | 04:36 AM
Shovels and Vettes's Avatar
Shovels and Vettes
I have most of the bolts off my 69 project in a big jug of this stuff......for over six months now......I hope it cleans them up?? I have heard of no hydrogen embrittlement problems with Evaporust......I sure hope there isn't.
Old Jul 12, 2022 | 05:25 AM
hunt4cleanair's Avatar
hunt4cleanair
Been using it for quite a while now. Here's another before and after example on a 73-74 454 EGR Valve "Hold Down" bracket.!
How did you finish the bracket...looks nicely original!
Old Jul 12, 2022 | 09:15 AM
interpon's Avatar
interpon
Also check tractor supply etc.. for sales..
i agree really great stuff... and all bare metal i use matte clear.. like this car bracket.. etc..(and a Lar's rebuild )
Water neck i left bare as OEM i assume and not bare steel.
NOTE lesson learned in winter.... IT WILL NOT WORK IF BELOW 70f.. read instructions..keep warm
To Evapo-Rust
Old Jul 12, 2022 | 12:42 PM
Tooch1's Avatar
Tooch1
Tom,
If the brackets are left in the stuff too long (as grantstigers mentions) it will take of the black oxide plating, pretty much down to bare metal. Actually, the one I posted above just has a light coat or two of clear matte sprayed over it. If I need to I just spray a very light coat of flat black over the part, then a light coat of satin clear over that to try to give it that black oxide appearance. Below, I attached a few photos of my collection (NFS)of big and small block EGR valve brackets, to show some differences. In the first photo the brackets at the left were left unfinished after I used EVAPO Rust to remove light surface rust. I removed them before it took away the oxide plating. The red arrow points to the bracket I posted above with the matte clear. Other brackets to the right in the photo have a coat of flat black with different amounts of clear applied. There are times however when the part is just too heavily rusted with pitting, and a wire wheel or filler is needed to smooth out the surface, obvious in the other big block bracket in the photo to the right of the red arrow. Probably way more info than you or the others wanted to know....but you know how I am!
Bottom line, this is a pretty cool product to use!
JP
73-74 350 & 454 EGR Brackets... Three on the left original black oxide patina. Four on the right light coat of flat black with clear applied.
Closeup after EVapo Rust (Matte Clear added to the bracket on the right)
Bottom side of the bracket I posted above to show the natural black oxide plating still present.
Here's an example of one I left in too long and EVAPO Rust took it and the bolt down to bare metal.
Old Jul 12, 2022 | 12:45 PM
Golferdad's Avatar
Golferdad
Yea,not sure if I would leave them in it that long,if it’s strong enough to remove rust,it’s some strong stuff,I have done small parts in a small container like bolts,and after a few weeks it seems to turn into a thick mess of gob,nasty.
Old Jul 12, 2022 | 01:15 PM
Golferdad's Avatar
Golferdad
Ready for paint.
