Hood Alignment Question
See images
look under the sticker
Is this an easy fix? It looks like all I need to do is re-align the hoodpins and it should close flush, no?
See images
I assume by the picture this is an aftermarket hood. So its difficult to diagnose the problem and a cure...
I'm guessing that if you look at how's its attached you'll figure a way to shim it. But the best way is to glass and shim
before paint
Lower the stop cushion out of the way completely, careful when closing the hood with the stop out of the way as it's in theory possible to push the mushroom pin up into the fiberglass
Then loosen the castle nut under the spring, hold it and thread the mushroom pin in some then snug up the castle nut, don't get too greedy, if you tighten it too much and have the alignment out you risk getting the hood stuck. Might want to tie some string to the latch releases on both sides just in case
There still needs to be a little spring movement left once it's adjusted
M
