68 Convertible Price question
Details;
GOOD
Solid frame, birdcage and body mountsHas new soft top and original hardtopNew bushingsNew trailing arms
Headlights come up and downPaint is driver qualityNew mufflers
4spd
BAD
Non numbers matching 327 (275hp in it now)
Non original paint.
Wipers do not workA few paint chips showing previous paint.
A few cosmetic interior flaws.
Some tail light issues (grounding)
Valve covers and distributor gasket leaksOil dipstick broken.
Exhaust leak from passenger side manifold
All in all I think it's a solid car with minor issues for the most part to fix.
What do you guys think the worth is?
Thanks in advance.
Engine code
Body mount and frame
Paint chip showing previous paint
No disrespect but how do you know the frame and cage are good? To what extent have you inspected for rust and/previous repairs?
Is the car a no-hit body?
When was it painted? What paint was used e.g. lacquer, enamel, PPG, DuPont, etc?
What history is available? How long has the current owner had the car? Why is he selling?
Is the transmission and differential original?
Agree the issues you raised are, generally, minor, as long as you have the time and ability to address. If you have to take the car to someone to work on it, that can be a slippery slope.
The 68’s have a lot of one year only parts so they are more problematic than the 69.
Haggerty rates a “good” condition 68 in the upper $20k range. Assuming no other glaring issues, I would guesstimate you’r looking in the $25-28k range.
What does the paint look like in person? It could just need a polish to get rid of the swirl marks, but in the reflection it looks like waves on the driver's door. Not a huge deal, I'm sure it shines up nice, but don't pay for perfection. To me, at least, a well painted black car is worth more than the 988 Cordovan Maroon it replaced, and good on the PO for not adding a forged trim tag.
I couldn't even guess a value. Perhaps you can get it for $20K, fix it up and it would be worth $25K? Maybe $25 and $30K? I really don't know what the NOM, or Canada, do to pricing.
I took a look at the bodymounts, frame rails and put a scope in the frame cut-outs to see inside and there was no rust or scaling on the outside or inside of the frame rails.
There was a incident in the rear right but the straps are all still in tact and you.see the pics of the rear lights the only indicator of an incident is the smallest of differences in trim reveal.
I don't know what paint was usedThe current owner has had it for 9yrs and it hasn't been driven for 2yrs (covered dry storage) previous owner to him I'm told didn't drive it for 10yrs.
The speedo doesn't work so actual miles are unknown but the odometer reading is 34k kms = 28k miles
Trans and diff are original 4spd M21
Thanks again for the reply, it sounds like you know a lot about these cars so hopefully my additions help
everything can be repaired and replaced, or modified if you like.
Pull those kick panels under the dash and look into the #2 body mounts. If you see piles of metal the top of the birdcage is bad. If the frame and cage are solid, she is a keeper.
it’s a 53 year old car, so we got to expect something
good luck to you Sir
My general advice is to think long term. Are you buying the car (or any other you may consider) for the joy of ownership of one of these cars? Along with the joy of ownership come the acknowledgment that you are buying a 55 year old Corvette which will need constant care and feeding. To some (including me) a good part of that joy derives from working on them, learning about them, interacting with fellow enthusiasts on how to fix them. In too many cases, however, people buy a car and then realize they are in over their head and/or experience the shock of the cost of finding a terminal issue (cage rotted), deciding shortly afterward that the paint wasn’t as good as it initially looked (it almost never does), then find out a paint job (today) costs about $10k and/or are frustrated that something quits working and they have no idea of what to do about it, each of which leads to disappointment.
Keep us posted.
Keep us posted.
As for reasons to buy a C3 it's 50/50 for me, half driving and half working on it in the garage over the winter.
Thanks, again and I'll keep you all posted
Just so you know and you will find this out, the 68 has some 67 parts, a lot of 68 only parts and anything that is sold as fits "68 to 82 does not" and a lot of "68 to 72" may not be. Other than that the hood may pop open on most rail road crossings and the body will flex so much when you jack it up you will think you broke it. ITs a great car and very fun. Make sure the brakes are the first thing you check and et working correctly
As mentioned the frame and birdcage are the key worry areas. Frame looks to have been repainted. Most C3s in this area I’ve seen do not have frame rust. But the birdcage can definitely hide some.. If exterior paint is decent, then it’s just mechanical. However as mentioned, this is not a factory black car, but rather maroon.
I have seen the local ad for this car. I don’t think you posted a link to the ad, so I will not as well to respect your reasoning. Lots going on under the hood that is not original. Steering wheel also not correct. Again this may not be important to you. To me the ask price is too high for a incorrect colour car based on some other local chrome bumper C3s I’ve seen for sale. $15-18K off the ask price might be ok if all checks out. Just my opinion.
