upper control arm wrench
Old Aug 29, 2022 | 06:42 AM
3X2's Avatar
3X2
Default upper control arm wrench
Anyone have or made a wrench to hold the upper control arm bolts from rotating when loosening/tightening the nuts?
Old Aug 29, 2022 | 07:30 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
These are a splined bolt, much like a wheel stud. they are pressed into the frame and the splines prevent them from turning.
If yours are turning you have bigger problems than making up a custom wrench.
Old Aug 29, 2022 | 08:34 AM
3X2's Avatar
3X2
I know they are splined. Makes it impossible to align the car with them spinning. I ordered new ones hoping the splines on the original bolts are just worn. It's been 40 or so years since I've had these out.
Old Aug 29, 2022 | 11:11 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Old Aug 29, 2022 | 11:14 AM
ralphspears
Banned Scam/Spammer
Old Aug 30, 2022 | 06:30 AM
4-vettes's Avatar
4-vettes
They should not spin. Perhaps someone pressed them out at one time. Then pressed them back in and the frame holes are now enlarged.
I would look into a bolt with a slightly larger spine.
Old Aug 30, 2022 | 08:11 AM
3X2's Avatar
3X2
Originally Posted by ralphspears
Could you measure the knurl diameter and knurl length and overall length without the bolt head? Maybe I can use ARP 7/16-20 wheel studs and use 7/16-20 locknuts
Old Aug 30, 2022 | 08:13 AM
3X2's Avatar
3X2
I had them out about 40 years ago when I replaced the upper control arm bushings. I guess I could do a mig tack weld to hold them or use a non locking nut and a lock nut as a secondary nut. Another possibility is to use a new wheel stud, depending on the knurl size of the oem bolt.
Old Oct 30, 2022 | 06:55 PM
69XR7's Avatar
69XR7
How did you end up resolving this problem? I just disassembled my entire front suspension and all four of my upper control arm studs were spinning free. I’m thinking I’ll have to find a new stud with larger splines.
To upper control arm wrench
