Strange Staring Issue
Old Sep 2, 2022 | 03:12 PM
Lark327's Avatar
Lark327
Default Strange Staring Issue
About a 18 months ago, I rebuilt my Quadrajet on my 72 because it was having a hard staring issue. I sealed the well plugs that cause that issue. About 2 months ago, I started having what seemed like the same issue, except the fast idle also seemed lower than it had been. I've only driven the car a dozen times in that time.The car is all stock with a divorced choke. Inspecting the carb on the car, the only thing I noticed was a little gas seepage on the upper (air horn) gasket. So I bought a rebuild kit. Dissambled the carb and saw nothing of concern, so put it back together with new gaskets. I did not change anything on the choke settings or anything else. After reinstalling the carb, it started and ran like it was supposed to with proper fast idle. Strange,
Old Sep 2, 2022 | 07:17 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
weeping at airhorn ?
float too high over fuel shut valve dirty with crud or worn?
