Thumping under seat
Old Sep 5, 2022 | 07:39 PM
Micmabbit's Avatar
Micmabbit
7th Gear
Default Thumping under seat
Hey again guys, I thought I fixed the problem, but apparently not. After my 79's warmed up, I feel a thumping sensation under my seat when stopped, in drive. I got a new distributor, cables, and had her timed since (about a month ago). I thought the problem dissipated, but I haven't really driven her much since, as I just got AC in her. Anyone have any idea what it could be? I took a look at the torque converter. And she's on tight and straight. I also have a problem where the motor putts once or twice after I cut it. Any help would be appreciated! Thank you gents!
-She's a 79 L48, original 350 small block and 3 speed automatic transmission
Old Sep 6, 2022 | 11:56 AM
OMF's Avatar
OMF
My guess is the exhaust is hitting where it passes through the transmission crossmember.
Old Sep 6, 2022 | 01:44 PM
wwiiavfan's Avatar
wwiiavfan
Especially if you have a bad motor mount.
Old Sep 11, 2022 | 11:26 PM
Micmabbit's Avatar
Micmabbit
7th Gear
took a look at the mounts and they look decent
Old Sep 12, 2022 | 07:35 AM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
Make sure it’s not happening when you first take off in drive. Does it go away easy you get some momentum and then come back after another stop?
Old Sep 12, 2022 | 10:43 AM
STL Zombie Hunter's Avatar
STL Zombie Hunter
St. Jude Donor '13
I had a thumping noise that was driving me nuts! It was my battery cable slapping against the body & / or driveshaft. The mount that holds it in place above the driveshaft had come loose.
Old Sep 12, 2022 | 10:52 AM
interpon's Avatar
interpon
pics of mounts? transmission and motor and snubber? jack up each side of engine and verify mounts good.. same transmission (gently)..
Old Sep 15, 2022 | 10:41 PM
Micmabbit's Avatar
Micmabbit
7th Gear
it doesn't happen when I start the car right up, only after ive driven a mile or two. When I start moving, it dissipates.
Old Sep 16, 2022 | 06:46 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Right under seat. I would look at exhaust bracket at the rear transmission mount. Bad transmission mount, etc.
Have you been under this car and had a look??
Old Sep 17, 2022 | 09:38 PM
Dodosmike's Avatar
Dodosmike
Something rolling around in the storage compartment? Lol
PO if my car had a thump during braking. Was a can of tire sealant bouncing around.
Old Sep 17, 2022 | 10:46 PM
Bluesting70
likely your snubber cushion.
Old Sep 18, 2022 | 01:40 PM
crf311's Avatar
crf311
Exhaust hitting
Old Sep 19, 2022 | 06:28 PM
Bluesting70
What was the diagnosis here?
Old Sep 20, 2022 | 06:49 PM
Micmabbit's Avatar
Micmabbit
7th Gear
snubber comes in tomorrow, I'll post an update after it's swapped out
Old Sep 24, 2022 | 02:04 PM
Micmabbit's Avatar
Micmabbit
7th Gear
  • replaced snubber, it still seems to sqaut when I throw her in drive. I'm about to take her out for a test drive
Old Sep 24, 2022 | 09:29 PM
Bluesting70
how did it go? What did the old snubber look like?
Old Sep 27, 2022 | 09:16 AM
Micmabbit's Avatar
Micmabbit
7th Gear
the old snubber was chewed up and cracked, definitely needed a new one
To Thumping under seat
