Brake Fluid
Old Sep 9, 2022 | 03:32 PM
Jim Coscette's Avatar
Jim Coscette
Default Brake Fluid
True or false? All dot 3 brake fluid is "synthetic."
Can I use ANY DOT 3 brake fluid in a 40 year old car with DOT 3 already in it?
Old Sep 9, 2022 | 04:29 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
False
yes
Old Sep 9, 2022 | 07:32 PM
kodpkd's Avatar
kodpkd
DOT-3 by definition is synthetic.
Old Sep 9, 2022 | 08:59 PM
C3 Stroker's Avatar
C3 Stroker
Dot 3 is synthetic, and compatible with Dot 4, which has a higher boiling point. Dot 5 is silicone based and does not mix with Dot 3 or 4.
Old Sep 9, 2022 | 09:21 PM
Bikespace's Avatar
Bikespace
It's really easy.
DOT 3, DOT 4, and DOT 5.1 are glycol-based, regardless of being "synthetic", and all compatible, but with ascending boiling points.
DOT 5 is silicone, is incompatible with glycol-based fluid, and may be completely incompatible with some recently made brake components (YMMV).
It's the most obvious numbering scheme ever!
Old Sep 10, 2022 | 07:56 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
yes
To Brake Fluid
