Under Dash Vacuum Lines - 1969
Old Sep 16, 2022 | 12:09 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Default Under Dash Vacuum Lines - 1969
I'm a big old guy and with size 14 feet I must have knocked these vacuum lines loose somehow. I've looked at the diagrams on Willcox but can't find them.
I only want to go down under there once, cause I may not be able to come back!
So before I contort, I was hoping you could tell me where the double end goes, and also the single tube.
And no, I haven't tried any switches to figure out what is not working, I'll still need to know exactly where they go
And if there's anything I can do to stop them coming off again.
Old Sep 16, 2022 | 01:51 PM
Mooser's Avatar
Mooser
The double connector should go to the wiper door override switch I think the right hand side of the wiper over ride switch, the single line if proably the one that connected to the "tach solenoid" which is bolted to the rear of the tach.
M
Old Sep 16, 2022 | 01:53 PM
Mooser's Avatar
Mooser
yours should be basically the same,
M
Old Sep 17, 2022 | 11:20 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
I agree with Mooser. You can try to use some zip ties to bind them to something higher.
To Under Dash Vacuum Lines - 1969
