Power antenna re builder
Old Sep 20, 2022 | 11:42 AM
Butchy's Avatar
Butchy
1st Gear
Default Power antenna re builder
Anybody know of any power antenna rebuild services for a 78 with a cb antenna. I believe the cable snapped. Thanks in advance.
Old Sep 20, 2022 | 12:13 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
There is a member here who I think does that. 78Kapsa or something like that. I will try to verify the forum name.
Old Sep 20, 2022 | 01:43 PM
Mark G's Avatar
Mark G
Not that difficult to do but it's one of those jobs that takes 3 hands and a little experience to see when things aren't 'quite' installed correctly (which can affect longevity). If you don't get it 'quite' right a guy will be taking it apart again ...lol. So maybe not a bad idea to have someone do it if you don't want to screw with it.
Old Sep 20, 2022 | 03:38 PM
interpon's Avatar
interpon
this is a 79 with same as 78 as it is an early build.
NOT a CB though
had great help here
https://www.corvetteforum.com/forums...na-wiring.html
Old Sep 20, 2022 | 05:57 PM
John 65's Avatar
John 65
Welcome to the forum. This place says they do repairs. (920) 686 - 0644
https://antennamastsrus.com/index.htm
Old Sep 20, 2022 | 06:15 PM
AB_in_AUS's Avatar
AB_in_AUS
KapsSA is the guru. He helped me get the right part for my early 79 with CB .. basically the plastic cable had snapped in the middle.
I ended up ordering 2 from info AntennaMastsRus.com
  • Delco Power Antenna Mast Cable MST-GM7
  • Delco Power Antenna Mast Cable MST-GM8
and I can't recall which one I used. I had to order the second (based on KapsSA's advice) because I ordered the wrong one. I Had the cut the cable to the required length (i think its a Cadillac part but does the job)
Attached are the instructions KapsSA sent me when I repaired mine about 8 years ago
File Type: pdf
Old Sep 21, 2022 | 08:23 AM
LenWoodruff's Avatar
LenWoodruff
Thanks for the post.
To Power antenna re builder
