Ekstra hot 12v by stereo
Old Oct 1, 2022 | 01:52 PM
Clakz's Avatar
Clakz
Default Ekstra hot 12v by stereo
I have installed a cassette player in my 82 and looking to also install a bluetooth dongle and an active noise filter on the power wire to the player. Both of these require power and ground.
Im a noob at car stereo stuff, but i guess they could benefit from having a separate 12v supply than the cassette player?
Any advice on where to grab extra power? Im not using my power antenna (no am/fm in Norway any more, only DAB &#128514 Would the antenna 12v wire work for my needs, or is it only on when the radio is active?
Old Oct 1, 2022 | 09:43 PM
bmotojoe's Avatar
bmotojoe
First, what make and model number is the cassette deck you installed?
Or show some detailed photos of it...
Your 82 original radio wiring should include 2 power connectors.
One should be a 2 wire connector (orange & black wires) and the orange would be Hot at all times for radios memory.
The second connector should have 3 wires, a Yellow a Black and a Grey.
The Yellow wire is a fused switched ignition source.
The Black wire at both connectors are grounds.
As far as Bluetooth adapter/dongle, unless your new deck already has internal Bluetooth capability you will need a external auxiliary 1/8" stereo jack input provision for a adapter/dongle.
