Both Electric And Mechanical Fuel Pump?
Old Oct 20, 2022 | 10:42 AM
hdeyong's Avatar
hdeyong
Default Both Electric And Mechanical Fuel Pump?
I have the same problem as everybody else with a '76 who is using volatile gas with alcohol added for good measure. Namely, the carb dries out if you don't drive the car for a couple of weeks.
So, I'm thinking an electric fuel pump. Turn the ignition on, wait for half a minute for it to refill the carb, start up and go.
But, why remove the mechanical pump?
The inlet valve of the mechanical pump will be opened by the pressure from the electric one, and the outlet valve will do the same thing.
I guess part of this is laziness, not having to remove the mechanical pump, re-route the fuel lines, block off the opening, etc.
But realistically, why not just leave it in place?
Any thoughts?
Old Oct 20, 2022 | 10:52 AM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Are you sure its not weeping out of the bowl? I know my Edelbrock does that. It has an internal leak. Another option is to install a check valve but it is easy to install an electric fuel pump. Its not really going to hurt having to take a few seconds to prime once more. It happens whenever my corvette sits in the garage for about 2 weeks without driving. It reminds me that I have to get out there more and drive. Now, I would have to say, I had have two rubber lines get ruined by the California rotten gas. Plus, I had to replace a fuel pump because the diaphragm melted by the same problem. Stabil will help with that problem.
Old Oct 20, 2022 | 11:46 AM
MelWff's Avatar
MelWff
wouldn't cranking the engine for 30 seconds or less, then step on the gas peddle 3 times to set choke and prime carburetor do the same thing?
Old Oct 20, 2022 | 11:54 AM
JavaJolt78's Avatar
JavaJolt78
MelWff,
Tx for the post and that's exactly what I have to do on my 78 even after Lars did his magic on my QJ..
Was always thing that an electric fuel pump may be the real answer???
Your thoughts/comments!!
JJ78
Old Oct 20, 2022 | 12:00 PM
MelWff's Avatar
MelWff
Originally Posted by JavaJolt78
MelWff,
JJ78
Other possibilities is your fuel pump output check valve is weak. Going electric seems like alot of work and a potential issue compared to cranking and pushing peddle every few weeks when you drive it. Not sure if mechanical pump inlet check valve is designed for pressure.
Old Oct 20, 2022 | 12:06 PM
JavaJolt78's Avatar
JavaJolt78
Tx for the note MelWff,
Yeah you are probably right about the electric pump even if one is available for my 78..
In any case can you pls tell me how to check the pump outlet valve and where can I locate it?? Or would it better to hand that job over to my Vette guy?
JJ78
Old Oct 20, 2022 | 12:07 PM
interpon's Avatar
interpon
this is where i'm leaning
crap replacement pumps are a crap shoot..i bet there is no check in the replacement pumps.. i wonder if a check valve can be put somewhere else..(in the steel line)? or a good pump.. i have a older new mexican Airtex pump i got that when the chinesium carter craps again will try..
FYI anything past 24 hours i need to crank 5-10 seconds then squirt again.. then it runs.. SOMETIMES it runs and stalls again.. so i am betting check valve lets it drain. i call it priming the oil pump .
carb still has 2 full squirts left even after 24 hours but is not enough to run until cranking
Old Oct 20, 2022 | 12:12 PM
hornetball's Avatar
hornetball
Whichever direction you go, consider a failsafe way to shut off fuel flow in an accident. A mechanical fuel pump stops when the engine stops. Modern FI cars have features that shut off the electric pump in an accident (usually tied to a tach signal). In older race cars, an oil pressure safety switch is commonly used.
I've got an electric pump on my race car that runs in series with the mechanical pump. My electric pump has a dedicated switch and I only use it for starting. Once started and stable, I turn it off. Car starts quickly, which is a good thing as high-compression can tax a battery.
Old Oct 20, 2022 | 12:13 PM
MelWff's Avatar
MelWff
JJ78
Inside the pump and not accessible
cv67's Avatar
cv67
St. Jude Donor '05
Read a discussion on teamchevelle where guys are doing that just for starting only
I can see where it may help...dont wanna destroy my starter.
If its sat for a long time you can use an old dishwash soap bottle, fill with gas and fill the bowls with it.
Old Oct 20, 2022 | 03:39 PM
Shovels and Vettes's Avatar
Shovels and Vettes
If you to have to crank for 30 seconds something is broke. I have had both a quadrajet and Holley on my 77, and it never required anywhere near that time….10 second max, normally less.
Old Oct 20, 2022 | 03:50 PM
MelWff's Avatar
MelWff
That's after letting it sit for a few weeks???
Old Oct 20, 2022 | 04:28 PM
Shovels and Vettes
I never had to crank 30 seconds even on the first start after restoration
Old Oct 20, 2022 | 04:54 PM
Bikespace's Avatar
Bikespace
I'd rebuild the carb before adding a fuel pump. If cranking is too hard, you can pour fuel into the carb manually.
My experience has been the same as @CorvettePassion. 10 seconds of cranking, even for a car parked a few weeks or months.
Do you have a proper fuel filter, with a check valve?
Old Oct 20, 2022 | 08:23 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Back in the day folks would add an electric fuel pump as a backup to the mechanical if they ended up with vapor lock. If your mechanical pump still works, run the electric pump, a type that is flow through, to prime the carb, then shut it off. I run just the electric and its pretty loud, not as loud as electric fans but you can hear it easily. Make sure you run a stand alone wiring system with its own fuse and a relay to power it. They can suck some juice and if its just added to your fuse block you may end up going through a lot of fuses....and it really sucks climbing under there to change them. For example I would add a fused line from the fuse block as a trigger wire to the relay and run a seperate 10 gauge wire from the battery to the new electric pump which has to be next to the tank as you need good head pressure to keep up with the flow demand and you dont want to collapse a rubber fuel line.
And I had a carb from Lars that still did what yours did, Either it had weeping plugs, a porous fuel bowl and it was soaking through the casting or just evaporating. I had the check valve fuel filter, a inline fuel one way check valve, plus new mechanical pumps all in at the same time....sometimes you cant fix it without spending money on a new one when the old one still performs well
Old Oct 21, 2022 | 06:10 AM
hdeyong's Avatar
hdeyong
It would, I guess I'm just trying to avoid the wear and tear on the starter.
Or, what if it's sat for a while and my wife gets mad at me and I have to make a quick getaway?
Old Oct 21, 2022 | 06:11 AM
hdeyong's Avatar
hdeyong
I've installed a good quality check valve in the line just before the carb and it helped, but after a few weeks, the problem is still there.
Old Oct 21, 2022 | 06:15 AM
hdeyong's Avatar
hdeyong
This is a great idea, just use it for starting and then shut it off. You're certainly right about a safety shut-off, too.
To Both Electric And Mechanical Fuel Pump?
