Is my ignition switch missing a wire?
Old Oct 24, 2022 | 12:41 PM
Jd21476's Avatar
Jd21476
Default Is my ignition switch missing a wire?
My car has not been shutting off with the key for a while and I had installed a kill switch until I got around to messing with it. Well today is the day. I pulled the switch and it looks like the bottom left spot may be missing a wire. Before I start digging around behind the panel for a pulled out wire, is that normal or should there be a wire there?
Old Oct 24, 2022 | 01:35 PM
Jd21476's Avatar
Jd21476
So after a little research it looks like it is the Ground wire and it is not used on the '68
