No sparak
Old Nov 17, 2022 | 08:50 PM
DionKrit's Avatar
DionKrit
1st Gear
Default No sparak
Hey guys, last night I made it a little further down the rabbit hole to see why my new 79 Corvette isn't starting. the car is getting fuel that's for sure, thought it might be the dizzy or ignition module although after some prodding around with a multimeter I've found out that there are no signals to the dizzy when I crank the car. The car tries to turn over like normal although no spark. Its weird because the car was running fine and then it just shut off and would start again. Anybody know what might be the cause on this mystery car?
What we know:
  • No Power at the spark plugs
  • No Power at the leads
  • No Power at the distributor
  • No Power at the wires going into the distributor
Old Nov 17, 2022 | 09:39 PM
Tech141's Avatar
Tech141
What did you do before/after the problem started?
Old Nov 18, 2022 | 02:26 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
OK. 79 Vette, HEI distributor. One power wire in. Usually a dark pink 10 gauge wire. If this doesn't get power with key on. Nothing else will.
Check all fuses. Check power into main switch, on column near the bottom. Check power out of main switch with key in run position, Is ignition switch adjusted correctly? And down the line you go.
You do have a wiring schematic for your car?
To No sparak
