Dash lights quit working 76 vette
Yes the ground plate is attached but only where the switch is, not to the speedo. The speedo only has one screw. I got the car like that. Could that be the problem? It’s never been attached to the speedo since I’ve been digging around with it and they used to work.
Do you have #7?
Is the black ground wire attached to the door jam?
Is the little LPS fuse good?
The dark green wire on the switch should have power when the switch is pulled. The voltage should change when you turn the ****. The INST LPS fuse should have the same voltage as the dark green wire.
You will only see voltage at the 5 AMP INST/LPS fuse when you pull the **** to either Head or Park position.
The Tail 20 AMP fuse powers that portion of the Headlight Switch.
Now about the Ground Strap and missing screw,
When you turn the **** full CCW a set of external switch contacts close sending a ground path to the Courtesy light circuit.
If "Both" doors are closed and you want your interior lights to come on, this will be the ONLY ground path available to the Courtesy light bulbs...
If you can find the missing screw great, or you could make up a jumper wire with an eyelet at each end and use the straps eyelet through bolting a screw and nut and then land the other end of your ground jumper wire to a good known chassis ground.
Here is another diagram showing the Headlight Switch ground path to Courtesy light circuit.
Looking at your new Headlight Switch connector pigtail, I believe it is now the Yellow Wire...
All plugged in.
Ground plate attached. The only screw I could fit in the hole is tapered at the head. I don’t think there’s anything wrong with that right?
Turned on, no lights.
It could be broken out of the box. Have you tried twisting the ****? While you have access, can you check for voltage entering and leaving the dash light dimmer circuit?
It looks like you can see the resistor element in your first image of your latest post.
Aside from changing all of the fuses, did you multi-meter both sides at the fuse panel? This is also helpful.
You can even quote from different sources, once you understand the format.
For checking voltage on the outbound side of the switch, a wire-insulation piercing test light is helpful, or you can get needle or wire piercing probes for your multimeter.
http://wordpress.keystonestatecorvet...m/?page_id=118
