Help identifying these screws
Old Nov 28, 2022 | 02:33 PM
Z51JEFF's Avatar
Z51JEFF
Default Help identifying these screws
I took the interior out of my 75 convertible for a deep clean and can't remember where these go
Old Nov 28, 2022 | 03:18 PM
Mooser's Avatar
Mooser
The ones on the back side of the door panels looked vaguely like those, held the deluxe trim onto the carpet edge ???
See 62corvettes answer below
M
Old Nov 28, 2022 | 09:42 PM
62corvette's Avatar
62corvette
They hold your rear storage compartment to the body.
Old Nov 28, 2022 | 09:54 PM
Mooser's Avatar
Mooser
I believe you're correct (mine have a raised washer but they are repros')
https://www.corvetteforum.com/forums...storation.html
Alan71
M
Old Dec 1, 2022 | 07:38 AM
Z51JEFF's Avatar
Z51JEFF
Thanks for the info,greatly appreciated.
Old Dec 2, 2022 | 08:32 AM
Eliredandblack's Avatar
Eliredandblack
I will chime in that, they are exactly like the screw/washers that holds the chrome trim
( on the deluxe door card bottom ) for the carpet piece. I know because one of my screw/washers got lost and I ended up having to fabricate one. Of course after I put the door card back on the car, I found the screw/washer. There were special because of the “egg crate material.”
Old Dec 3, 2022 | 01:11 AM
Z51JEFF's Avatar
Z51JEFF
These screws,washers are polished which would tell me they are trim screws meaning they will be seen.
Old Dec 6, 2022 | 07:03 PM
'73and'75's Avatar
'73and'75
Hello Z51JEFF,
I wanted to confirm what was stated above. The screws you were wondering about are used to attach your rear compartment frame.
To confirm, check them along side a nickel.
This screw I removed from my rear compartment frame.
This screw is from an NOS Deluxe door panel
You can easily see that the captured washer used with the rear compartment frame screw is much smaller than the captured washer used with the door panel screw. As you mentioned earlier, these rear compartment frame screws have a much nicer finish (shinier) than the door panel screws.
To Help identifying these screws
