L shaped brake pads
Old Dec 4, 2022 | 08:16 AM
cottoneg's Avatar
cottoneg
Default L shaped brake pads
Were L shaped brake pads only on the L-88 Corvettes? Was it an option.
Anyone have a picture?
Old Dec 4, 2022 | 09:12 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the J56 calipers that was standard on L88 cars had a heavier duty mounting brackets and the calipers had two pins, plus a prop valve. not sure what you mean by a "L" pad
Old Dec 4, 2022 | 09:34 AM
Mooser's Avatar
Mooser
Maybe he means the side profile with the bend in the backing plate?
J56 pads.
M
Old Dec 4, 2022 | 09:46 AM
cottoneg's Avatar
cottoneg
That is EXACTLY what I meant.
Thank you both!!
Old Dec 4, 2022 | 09:59 AM
69L88's Avatar
69L88
While all L88s came with the J56 option, that option was available from 1966 to 1975 IIRC.
Old Dec 4, 2022 | 10:23 AM
Mooser's Avatar
Mooser
, (might have started in 65?)
Doesn't help that they started using that same option code on the C6 and C7 and it's still listed for the C8
M
Old Dec 4, 2022 | 11:36 AM
cottoneg's Avatar
cottoneg
Hawk may have discontinued their pads. I asked Carbotech and they replied
Yes, we can apply new material to your old backing plates but they must be free of the old pad material before you send them in.”
I still have some life in my pads. Anyone knows if you can purchase either the backing or backing with pads?
Old Dec 4, 2022 | 04:08 PM
69L88's Avatar
69L88
You can try Duntov Motors but be advised they just filed for bankruptcy.
Old Dec 5, 2022 | 01:34 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
One 1969 L-88 was delivered without J-56 brakes under a COPO order. The rest of the 1967-1969 L-88s were equipped with J-56. Your comments on availability are absolutely correct… J-56 from 1966 to 1969 (1967 to 1969 with L-88 only), 1970 to 1972 as part of the ZR-1 and ZR-2 options, and 1973 to 1975 as part of the Z-07 option.
https://www.corvetteforum.com/forums...ng-plates.html
The seller shows a photo of a magnet not being attracted to the backing plates. The originals were made from inconel which is a high temperature nickel alloy which is non-magnetic. $275 seems like a deal… I remember about ten years ago an nos set of pads would set you back $1000.
Regards,
Stan Falenski
To L shaped brake pads
