Replace brake lines?
Old Dec 4, 2022 | 04:12 PM
69XR7's Avatar
69XR7
Default Replace brake lines?
I am in the process of rebuilding my front and rear suspension. No upgrades, mainly just replacing worn out joints and bushings. I’m trying not to get into anything that isn’t “necessary” but It’s a challenge for me to contain myself from “scope creep” and not start changing things out just because they are old. Also would like to contain the budget where possible.
So as the title says, while the entire suspension is out and I’m already rebuilding the calipers should i take this time to replace all the brake lines?
There are no visible issues with them aside from a little surface rust. This car spent most of its life in California and is solid.
What say you?
Old Dec 4, 2022 | 04:44 PM
Skootter14's Avatar
Skootter14
At a minimum, soft lines may be worth replacing while you're at it, since you'll have to bleed the brakes anyway. If there are no visible issues and the brakes work fine...I'd do the soft lines.
Old Dec 4, 2022 | 05:12 PM
interpon's Avatar
interpon
Unless the flare, threads, or head is bugared from pliers vice grips..i would leave them alone.
but they do look good with new springs around the brake lines
Old Dec 4, 2022 | 05:17 PM
69XR7's Avatar
69XR7
Yes, i should have said that I am replacing the rubber lines. It’s the hard lines that i was thinking about. It would look nice, and it’s not too much work, but it’s another couple hundred bucks for something that I don’t NEED.
It’s just too easy to put things in your shopping cart. Everyday has been like Christmas since i bought this car and it’s getting time stop buying parts and just drive the damn thing
Old Dec 4, 2022 | 06:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I did it and it was pretty easy. I replaced the long drivers side by snaking it though the crossmember from the rear. Soak all the T's and connections before hand so you can get the rusted or seized fittings out easily. I got all my lines from Inlinetube.com
https://www.inlinetube.com/collectio...Brake%20Lines|
I went with stainless lines and stainless flex lines. they have the rubber too...https://www.inlinetube.com/collectio...Brake%20Hoses|
Old Dec 5, 2022 | 01:56 AM
CarterDawson's Avatar
CarterDawson
I replaced all my calipers and rubber lines. I only replaced my rear hard lines because there fittings were stripped. If I were you and I was trying to stay on budget I would just let the main lines stay. For me it wasn’t worth the hassle. They work fine and don’t leak so I left them. Just my thought, if they work, and don’t leak, leave them. But if you want them looking fresh, replace them.
Old Dec 6, 2022 | 06:54 AM
derekderek's Avatar
derekderek
the hard lines are not young. i think once a year or so when brakes are fully bled and working, stand on the brakes like a 3 year old just chased a ball in front of you. if you are gonna pop a line with emergency brake pressure, better to do it in your driveway stopped.
Old Dec 6, 2022 | 11:50 AM
Lt.Mike's Avatar
Lt.Mike
If the hard lines give you any reason to question their integrity you’ve already got your answer, replace them.
The main lines on my ‘68 looked ok but I had to replace the rear calipers so I replaced the headlines from the rubber hose back. Didn’t replace the rubber hose and that came back to bite me.
The right rear line collapsed inside creating a one way valve locking up the caliper. I released the bleeder and the caliper relaxed it’s grip on the rotor.
It was then I replaced all the rubber brake lines.
On the hard line I replaced with stainless. For the longer lines I’ve turned to using something called Ni-Cop a nickel copper mix available at autozone. It is extremely easy to work with and will not rust !
Old Dec 7, 2022 | 11:59 PM
68/70Vette's Avatar
68/70Vette
You can replace the metal brake lines with the body on. The problem line is the one that runs along the driver's side frame rail. Of course, it'd be easy to remove this line by cutting it up in small sections...but don't. The trick is to remove it in one piece. Why? Because when you remove it in one piece, then installing the new line is simply the same as removing it, but doing it in reverse. The first time you do this will take a long time. By the third time I removed and replaced a line, I could do it pretty quick.
Old Dec 8, 2022 | 12:07 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie suggestion...if the steel lines are badly pinched-replace them. If there are thick rust spots-sand (by hand) the rust off the steel line/pump the brakes hard as suggested above to see if there is gas weeping from the areas you sanded. Replace the line at the SLIGHTEST sign of gas weeping.
Old Dec 8, 2022 | 09:51 AM
MAD Matt's Avatar
MAD Matt
If they have never been replaced, do the math. They are over 50 years old! I'm an old school hot rodder and my motto is...."Do it nice or do it twice." Is saving 200 bucks really worth it in the long run?
Old Dec 8, 2022 | 11:25 AM
Lt.Mike's Avatar
Lt.Mike
if you’ve got think rust replace them !
Rust by itself will weaken the line and sanding them is removing metal till it looks nice but you know it’s thinner and weaker now. This is nothing to skimp on. You’d spend big money on a stereo but your brakes are you and your passengers safety. Make it right.
Old Dec 8, 2022 | 11:26 AM
Lt.Mike's Avatar
Lt.Mike
Exactly !!!
Old Dec 8, 2022 | 11:49 AM
Hopper12's Avatar
Hopper12
I did the suspension (everything), rear, brakes, etc. on our '68 a year or so ago. The car doesn't have a ton of miles on it and the hard lines looked really good as far as wear is concerned, but they didn't look all that nice when compared to all the new/refurbished parts I was putting back.
So, I decided to do the hard lines while I was at it. As I was removing the hard line that goes across from one rear to the other side, it broke in half! The hidden wear was under one of the clips. I would never have known, until it failed. Your lines are 50+ years old. I wouldn't even think twice.
  • I've used stainless lines and steel lines. I went with steel because stainless can be quite a bit harder to work with and seat. Besides, if the first steel lines lasted 50 years, I'll be looooong gone by the time these are shot.
  • I coat items like this with high temp satin clear. It keeps whatever I coat looking like new for years. https://smile.amazon.com/dp/B000CPJL...Bsatin%2B&th=1
  • I also bought new brass blocks. They're not that expensive, look great, and seat really well.
  • Get new clips and it'll look even better.
  • As others have said, the front/rear drivers side is the most tricky, but you'll get it. Some of the clips are a bit hard to get a wrench on, just soak them and use the right wrench and you'll figure it out.
  • This thread may have a few helpful posts and pics. https://www.corvetteforum.com/forums...n-there-2.html
I know a lot about scope creep. We all suffer from it. But brakes are one area where I believe the scope should include most everything anyway.
Keep us posted. Best, Paul
Old Dec 8, 2022 | 01:51 PM
Winchester67's Avatar
Winchester67
Another consideration is how long are you planning on keeping the car? If this is your dream Vette and you are never going to sell it, I say replace them now while you are already dirty. If this is a stepping stone Vette towards your dream car, well, if they are working fine I would probably keep them.
Old Dec 8, 2022 | 02:47 PM
derekderek's Avatar
derekderek
I don’t think how long you were going to keep the car has anything to do with how well you do the brakes. If you don’t keep the car, somebody’s going to pay you money for it. And then they are essentially trusting that what you did you did right. And when it comes to making something stop, people really need it to be done right.
Old Dec 8, 2022 | 02:54 PM
Winchester67
Derek, I agree. And personally for $200 it is not even worth discussing in my mind, but I remember trying to finish a car on a strict budget and if the existing lines are solid and money is tight...I get where he is coming from so I offered that angle in case he had not considered it. As I said, I would replace them. But he is asking for opinions, so I offered mine.
To Replace brake lines?
Old Dec 10, 2022 | 05:18 PM
crf311's Avatar
crf311
You need to lift the body to replace all the lines.
Old Dec 10, 2022 | 07:34 PM
Rescue Rogers
no you dont...I did all mine in a 4 speed car without lifting the body
Old Dec 13, 2022 | 03:43 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...did both my '68 4spd conv & '75 L-82 auto coupe without removing the body. The hardest part is getting to the fittings at the rear main line junction fitting, especially if the car has some and/or rust.
