Fuel tank gallons? Need help
Old Dec 7, 2022 | 04:07 PM
joescvette's Avatar
joescvette
Default Fuel tank gallons? Need help
Need help, On a 69 corvette when I add 4 or 5 gallons to the tank it reads full, then slowly goes down as I use it. Right now I have 1/4 tank, showing 4 inches of fuel with a yard stick. Does anyone know about how many gallons are left in the tank? I could use any kind of help, thanks
Old Dec 7, 2022 | 04:30 PM
sunflower 1972's Avatar
sunflower 1972
Old Dec 7, 2022 | 04:42 PM
joescvette's Avatar
joescvette
Not sure what you are showing me. I need to know how many gallons are in my tank. w/4 inches showing on my yard stick. Can you measure how many inches of fuel are in your tank, w/the gauge showing 1/4 tank. Thanks
Old Dec 7, 2022 | 05:03 PM
sunflower 1972
Just showing that you have a 20 gallon gas tank. Perhaps you or someone could do some calculations. I sucked at math.
Old Dec 7, 2022 | 05:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
You would have better luck with a Lottory Ticket than finding someone with a quarter tank and the correct year of tank.
You need an Ohm Meter. Somethings not right with the sender.
All gauges will read "dead" when no power is available.
Most gauges will read too high with power, but poor ground.
It's a perfect GRD and resistance that brings the gauge needle down into perspective measurements.
Maybe someone will chime in with what your Ohms should read with IGN switch on and less than 1/2 tank.
Old Dec 7, 2022 | 05:24 PM
joescvette's Avatar
joescvette
Thanks a lot
Old Dec 7, 2022 | 07:19 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you have to do it the hard way like I did.....pull the fuel pump supply line and drain your tank. Fill one gallon jugs and pour it in and measure it. 4 inches is only going to mean something to you becasue of your actual suspension setting, tires, and if you are parked on a totally level surface and the fact that the bottom of your tank is inclined, not flat. If you want to get your tank to read correctly with your gauge its about the only way to do it and get a very expensive fuel gauge calibrator
https://www.summitracing.com/parts/cin-sn34
I use this and my tank when it just hits empty has about 2 gallons in it....mine reads full fo r a while before it drops because you bury the float in fuel for a bit with the older bottom sensor tanks.
Do not use a gauge calibrator like Wilcox's variable resistor for the temp gauge. We tried it , it gets very hot and isnt accurate with the fuel gauge
Old Dec 7, 2022 | 09:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Wild guess = 5 gallons left at 1/4 tank showing on AN ACCURATE guage.
Old Dec 7, 2022 | 11:03 PM
Bikespace's Avatar
Bikespace
Have a drywall bucket ready. Drain the tank. If it overflows, you had more than 5 gallons left in the tank.
The tank is not flat on the bottom. If you know where the tank is 4" deep, you can drop your spare tire, roughly measure the wet volume, and do some math. 231 cubic inches is about one gallon.
Old Dec 7, 2022 | 11:59 PM
doorgunner's Avatar
doorgunner
You members probably know the old school trick of bending the float arm slightly so the tank still has 3 gallons remaining when the (accurate) gauge needle just "touches" the E mark.
It gives you 30-40 miles of drive time to reach a gas station or Rest Area.
Old Dec 8, 2022 | 12:24 AM
joescvette's Avatar
joescvette
Thanks very much for all your help, everyone
Old Dec 8, 2022 | 07:53 AM
HeadsU.P.'s Avatar
HeadsU.P.
And then there were the '76 Chevy Caprices that had the float arm bent the other way.
Pushing that damn car up to the pump with still 1/8 tank showing was not my fun & joy.
Old Dec 8, 2022 | 02:35 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
I don’t know why you are even asking this question and what the relevance is?
If you are trying to determine how much gas you have before you are truly empty just drive it until you run out and have a premeasured can with you so you can get back to a gas station to fill up to determine what your car really holds.
Old Dec 8, 2022 | 02:54 PM
Tiger Joe's Avatar
Tiger Joe
For the hell of it I stuck a yard stick in my 68 tank. I can fill my tank to the bottom of the filler neck- 10.5”.
so I would say 4” would be more than 1/4 tank. Closer to 8 gal than 5
Old Dec 8, 2022 | 03:37 PM
joescvette's Avatar
joescvette
Thanks Tiger Joe, That's what I was lookin for
Old Dec 8, 2022 | 04:00 PM
Motorvation's Avatar
Motorvation
So mathematically, 20gallons divided by 10.5 inches is1.9 gallons per inch. If you multiply 1.9 gallons per inch by 4 inch that equals 7.6 gallons. Looks like in equations: 20 gallon/10.5 inches= 1.9 gallon/ inch. Then 1.9 gal/in X 4 in = 7.6 gal You know you are correct because the inch (in) units cancel out; it’s actually one [ in/ in] . This takes the assumption that the tank is the same size( volume) bottom to top. As the great Greek philosopher Mediocrate says “Meh, good enough”.
And if you don’t want to wade thru the BS all the time, fix the wires and/ or change the sending unit and be done with it….
Steve O.
Old Dec 8, 2022 | 04:21 PM
Dino_'72's Avatar
Dino_'72
Per earlier post. 69 has a 20 gallon tank. Next time you’re on E, fill tank. 20 minus what you put in is approx your reserve.
On my 72, when my gauge reads E I have about 3 gallons. Never used yardstick to measure. But it’s around 4”.
To Fuel tank gallons? Need help
Old Dec 8, 2022 | 11:52 PM
joescvette's Avatar
joescvette
OK, Thanks for all the input
Old Dec 12, 2022 | 03:53 PM
mh_merc's Avatar
mh_merc
Why drain the tank? Just siphon the 4" out and see how many gallon jugs you can fill with it.
Old Dec 14, 2022 | 10:05 AM
derekderek's Avatar
derekderek
Buy ethanol free gas and keep it full.
